Hi
I've done the connections. I've got about 60,8 ohm between the connections REQ- REQ+ , CLK- CLK+ , MTH- MTH+ , HTM- HTM+
I get it in RUN mode and the oil pump is spinning. I got a single throttle connected and calibrated 10 over and 10 under the values.
I got 60V going in to the inverter. But I can't get it to spin.
When I have ReGen programmed I can feel how it holds back when I turn the prop shaft and the transformer shows voltage above the 60V and sometimes goes in some secure mode.
I enclose all readings and settings. Please help me someone who understands this. I'm sure I have some settings wrong.
As you can see on second pic is that status goes into POTPRESSED when I press the throttle.
Zombie and GS450H connected but no spin Topic is solved
- IMG_1575.jpg (94.17 KiB) Viewed 274626 times
- IMG_1576.jpg (38.42 KiB) Viewed 274626 times
- IMG_1577.jpg (36.63 KiB) Viewed 274626 times
- IMG_1578.jpg (36.1 KiB) Viewed 274626 times
- IMG_1579.jpg (94.46 KiB) Viewed 274626 times
- IMG_1580.jpg (35.63 KiB) Viewed 274626 times
- IMG_1581.jpg (39.55 KiB) Viewed 274626 times
- IMG_1582.jpg (37.87 KiB) Viewed 274626 times
- IMG_1583.jpg (36.66 KiB) Viewed 274626 times
- IMG_1584.jpg (33.26 KiB) Viewed 274626 times
- IMG_1585.jpg (37.1 KiB) Viewed 274626 times
- IMG_1586.jpg (36.95 KiB) Viewed 274626 times
- IMG_1587.jpg (37.86 KiB) Viewed 274626 times
- IMG_1588.jpg (93.86 KiB) Viewed 274626 times
- IMG_1589.jpg (37.27 KiB) Viewed 274626 times
- IMG_1590.jpg (36.58 KiB) Viewed 274626 times
- IMG_1591.jpg (38.13 KiB) Viewed 274626 times
- IMG_1592.jpg (38.95 KiB) Viewed 274626 times
- IMG_1593.jpg (35.89 KiB) Viewed 274626 times
- Has thanked: 329 times
- Been thanked: 847 times
royhen99
- Has thanked: 22 times
- Been thanked: 134 times
Re: Zombie and GS450H connected but no spin
As you are running without a shunt, as well as setting udcsw to 0V you also need udcmin set to 0V otherwise the torque setting will be 0.
I hope the .JSON is attached...
- params (1).json
- (1.94 KiB) Downloaded 386 times
UDCmin is set to 10, it is not using a Shunt so set it to 0.
