Zombie and GS450H connected but no spin Topic is solved
JappeEs
Has thanked: 8 times
Post by JappeEs »
Hi
I've done the connections. I've got about 60,8 ohm between the connections REQ- REQ+ , CLK- CLK+ , MTH- MTH+ , HTM- HTM+
I get it in RUN mode and the oil pump is spinning. I got a single throttle connected and calibrated 10 over and 10 under the values.
I got 60V going in to the inverter. But I can't get it to spin.
When I have ReGen programmed I can feel how it holds back when I turn the prop shaft and the transformer shows voltage above the 60V and sometimes goes in some secure mode.
I enclose all readings and settings. Please help me someone who understands this. I'm sure I have some settings wrong.
As you can see on second pic is that status goes into POTPRESSED when I press the throttle.
Has thanked: 329 times
Been thanked: 847 times
Re: Zombie and GS450H connected but no spin
where is the .JSON with the parameters?
JappeEs
Post by JappeEs »
Where and how can I get .JSON?
royhen99
Has thanked: 22 times
Been thanked: 134 times
Post by royhen99 »
As you are running without a shunt, as well as setting udcsw to 0V you also need udcmin set to 0V otherwise the torque setting will be 0.
JappeEs
Post by JappeEs »
I hope the .JSON is attached...
params (1).json
(1.94 KiB) Downloaded 386 times
royhen99 wrote: Wed May 08, 2024 5:10 pm As you are running without a shunt, as well as setting udcsw to 0V you also need udcmin set to 0V otherwise the torque setting will be 0.
UDCmin is set to 10, it is not using a Shunt so set it to 0.
JappeEs
Post by JappeEs »
Thank you Sir ! We have a spin :D
