Outlander rear motor and inverter
Been thanked: 413 times
Re: Outlander rear motor and inverter
Well outlander rear motor rating is 60kW. That would be 320V x 185A = 60kW cca. But i would think rear motor can drive 100kW easily...
Now rms rating is another thing... i have seen 600A igbt inside rear inverter. If you have option set inverter phase current to say 500A or 20% below transistor rating. OC limit however you can set more as it is transient value limit.
OutlanderDonor
Post by OutlanderDonor »
I calculated nominal 30kW / 300V = 100A (60kW is maximum and 300V nominal battery V). I am thinking of measuring temperature of motor, and if it gets too hot, I'd know what the limit is. But I do not know what temperature sensor they are using,
OutlanderDonor wrote: Wed Nov 09, 2022 1:22 pm I calculated nominal 30kW / 300V = 100A (60kW is maximum and 300V nominal battery V). I am thinking of measuring temperature of motor, and if it gets too hot, I'd know what the limit is. But I do not know what temperature sensor they are using,
No 60kw is battery rating. Motor is rated together with system and that should mean like 30min rating. Really i dont know why you fuss about this so much. Go ahead make your own system and test it. I am sure 100kW would be your max rating and 40kW hour rating. Liquit cooled motors are so much better at this than air cooled.
I am sure someone here already posted N rating of RWD thermistor. Go on and read the threads. I am sure you can contribute to wiki when you find out.
rstevens81
Has thanked: 29 times
Been thanked: 114 times
Post by rstevens81 »
define too large :)
The OEM Vw Passat packs use 300a!
https://openinverter.org/wiki/VW_Hybrid_Battery_Packs
The OEMs seemed to have designed the fuse to continuous rating but the contactors to peak rating 😆
markc5442
Has thanked: 4 times
Post by markc5442 »
Hi All,
Haven't posted for a while due to frustration at not getting my motor to turn, taking rests from working on it for a think etc. But, finally, the day arrived - had to learn how to use timers in the Arduino ...
Anyhow, the motor starts to turn at nearly zero voltage (no more than 20VAC) - I'm using a VARIAC through a bridge rectifier. I start the motor by first starting my Arduinos (one to send; one to receive). I then supply the low voltage side of the inverter via a power supply. I then plug in and start to turn the dial on the VARIAC.
I was told previously that the inverter requires ~200V to activate but thus does not seem to be the case.
Have I broken something or should I not worry?
markc5442
Post by markc5442 »
ScottS wrote: Thu May 20, 2021 10:32 pm Hello All,
Good to see some more people having luck with these components. I'm still having a bit of trouble actually getting the inverter activating and motor turning despite being pretty confident we're sending all the right messages. I feel like it's a sequencing issue on start-up, I think I can see the inverter going through various states but not getting it in to the drive state. I wonder if there's a particular sequency of applying power, sending CAN messages, RSDN and setting the inverter enable signal then sending torque request?
Have a video here is anyone has any ideas, would be appreciate
Scott, did you get your motor to spin? If not I may be able to help.
Mark
Zapatero
Has thanked: 27 times
Been thanked: 58 times
Post by Zapatero »
tom91 wrote: Tue Mar 01, 2022 9:12 pm I just got my new Ender 3 S1 setup and wanted to test some small prints.
Have been in the progress of designing ways of reusing the Rear motor and Inverter, the biggest issue is the connectors.
I have now designed a basic connector starting point that use the "dupont" style header connectors.
The attached STL works for both the Vehicle connector and the Motor connector of the rear inverter and thus also on the motor. Will be working on making the print better to eventually include a seal and allow for potting the wires.
I bought this set of connectors and figured it's not an exakt fit. Am I doing something wrong? The horizontal distance of the pins fits perfect, but the upper and lower rows are further apart on the inverter pins than on the plug
I know the plug in my hand has 2 pound too much, i just wanted to show the vertical distance and had this laying around
Zapatero
Post by Zapatero »
I guess o figured out of already :) i should use two single row connectors?!
Has thanked: 330 times
Been thanked: 848 times
Zapatero wrote: Wed Dec 28, 2022 10:22 pm I guess o figured out of already :) i should use two single row connectors?!
Yup that is needed in my print there is a little nub between them for spacing.
evMacGyver
Has thanked: 73 times
Been thanked: 11 times
Post by evMacGyver »
markc5442 wrote: Wed Dec 21, 2022 6:47 pm Scott, did you get your motor to spin? If not I may be able to help.
Do I assume correctly that rear motor with rear inverter are good to go using CAN bus? I'm thinking these for my next project, so I'm just verifying.
Zapatero
Post by Zapatero »
Yes, +12v, ground, CAN L and CAN H - that's it
you have to pull the shut off pin to ground, too...
DkubusEV
Has thanked: 146 times
Been thanked: 15 times
Post by DkubusEV »
Does anyone know if it's possibly this simple with Imiev motor and matching inverter?? That would be awesome...
AWD custom sports car ev6-gt based
6x6 Mercedes truck triple drive units from mg-ZS
1990 Daihatsu charade G100 3 door hyper9 .
markc5442
Post by markc5442 »
Zapatero has described the LV connections to the inverter. If you read this thread all the way through you will find the pin out description for the plug into the inverter and the various CAN messages required to enable the inverter and make a torque command.
markc5442 wrote: Fri Dec 30, 2022 7:54 am Zapatero has described the LV connections to the inverter. If you read this thread all the way through you will find the pin out description for the plug into the inverter and the various CAN messages required to enable the inverter and make a torque command.
This thread is for the Outlander not Imiev. So you need to find some can logs from an Imiev to see if the messages match.
aot93
Has thanked: 8 times
Been thanked: 49 times
Post by aot93 »
DkubusEV wrote: Fri Dec 30, 2022 2:27 am Does anyone know if it's possibly this simple with Imiev motor and matching inverter?? That would be awesome...
This has been asked a few times, you could collect some CAN logs as Tom says or someone with a motor and inverter could just try it - I'm happy to help with this if required.
DkubusEV
Post by DkubusEV »
tom91 wrote: Fri Dec 30, 2022 10:53 am This thread is for the Outlander not Imiev. So you need to find some can logs from an Imiev to see if the messages match.
Cheers, not trying to hijack or annoy anyone. I started a thread for Imiev a while ago but unfortunately not much info available yet, (other than suggestions telling me that I should check out the outlander threads). So I'm keen to learn the differences as soon as I can.
DkubusEV
Post by DkubusEV »
aot93 wrote: Fri Dec 30, 2022 11:09 am This has been asked a few times, you could collect some CAN logs as Tom says or someone with a motor and inverter could just try it - I'm happy to help with this if required.
That would be awesome if you have access to either an Imiev and or a Imiev running gear to get can logs from. Unfortunately I'm still waiting on my zombie verter vcu so can't do much yet. I do have a full Imiev (without battery pack though) so I can't power it up and use it for logging as a standard car. Again sorry to post here regarding Imiev stuff but your thread has been more helpful than any Imiev ones I've seen so far. Cheers guy's.
Ctwidle
Been thanked: 12 times
Post by Ctwidle »
I’ve been playing around with fitting an Outlander rear motor into my 74 bug with a Toyota inverter but got bogged down with an inadequate power supply and confusion over FOC tuning and have been waiting for some sort of battery to become available in Aus. Last week I thought I had struck gold. A repairable write off 2014 PHEV outlander came my way for a cheeky £750 at auction. Getting it home was an adventure and it looks like it could probably be returned to use but that’s not why I bought it!
Even if the HV battery is dead there are enough other bits to make it a worthwhile purchase and there could even be a profit in breaking it.
I charged the 12v battery and it came to life but won’t start. Dash reports a need for ‘EVS service’ and ‘RBS service’ and HV battery is empty. There is only a type 1 socket and it didn’t come with a charge cable so I can’t do much til next year😪.
I have also ordered a Watchdog compatible OBD tool.
2 questions please:
I only intend charging at home from a standard wall socket and was wondering if it was at all possible to bypass the type 1 socket with ac without too much trouble (or risk)?
If I remove the service disconnect plug is it possible to read the pack voltage and does the car need to be turned on?
Happy new year to one and all,
Chris
I think i demonstrated on Mitsu charger thread you can run it with 1khz pwm generator set to 25% duty. Charger needs Cp signal to pull in and some way to get AC at the same time.
Really the most reliable way would be to get a L1 charging cable per protocol.
Ctwidle
Post by Ctwidle »
Thanks Arber333, I was just wondering if there was a way of getting some charge into the battery as quickly as possible. I have no way of confirming if it is fully discharged or how long it has been that way and it may be some time before I can source a charge cable as Aus is pretty well shut down for several weeks.
aot93
Post by aot93 »
The contactors are inside the battery pack and if you can't them to close you will not be able to measure HV with a meter.
If the contactors are closing you could measure at the front or rear inverter.
HV should be reported on OBD data some where and also on the CAN bus.
The service manual has loads of good info, http://mmc-manuals.ru/manuals/outlander ... dex_M1.htm
Ctwidle
Post by Ctwidle »
Thanks for that, I wasn’t aware the manuals were so freely available - looks like I have a bit of reading to do while I wait for my OBD to arrive + starting to climb the CAN network mountain.
marcexec
Has thanked: 1042 times
Been thanked: 111 times
Post by marcexec »
Ctwidle wrote: Sat Dec 31, 2022 11:02 am Thanks Arber333, I was just wondering if there was a way of getting some charge into the battery as quickly as possible. I have no way of confirming if it is fully discharged or how long it has been that way and it may be some time before I can source a charge cable as Aus is pretty well shut down for several weeks.
IIRC it has a type 1 connector same as the Leaf - you could ask around to borrow a granny cable.
Not that many Leafs in Australia, though 🤔
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Tomas
Has thanked: 42 times
Post by Tomas »
Is there any option if I want to use other cables than stock between motor and inverter? Printable housing or something like that to get it waterproof?
Domt177
Been thanked: 13 times
Post by Domt177 »
Anyone know if one of these can be run in reverse (I.e flipped 180 degrees)
The only issue I can think of is if there is an oil pump which only runs in forward gear
