GAZ-24 Volga 1983г.
Vijaya
GAZ-24 Volga 1983г.
Post by Vijaya »
Hello dear friends.My name is Vadim,I'm from Russia.Please give me some advice where to buy me the simplest electricity and a motor to make it go? I don't understand anything yet. My compliments to yo
Vijaya
Re: GAZ-24 Volga 1983г.
Post by Vijaya »
Vijaya wrote: Mon Jun 07, 2021 10:13 am Hello dear friends.My name is Vadim,I'm from Russia.Please give me some advice where to buy me the simplest electricity and a motor to make it go? I don't understand anything yet. My compliments to yo
Vijaya
Post by Vijaya »
Welcome, sexy photo :D
Cheapest option is probably Toyota Prius Gen2 inverter & transaxle plus a hybrid battery. We have some Russian speakers here who are using this.
Vijaya
Post by Vijaya »
Thank you dear friend.Please introduce me to Russian speakers and I will send you super sex photos and videos.
jnsaff
Been thanked: 8 times
Post by jnsaff »
The Volga is RWD so maybe easier with the GS450h gear? You could probably also make it the fastest (and scariest) Volga in the world, for about 3 minutes until the diff or driveshaft or something else only meant to only handle about 100hp breaks.
Vijaya
Post by Vijaya »
This is the best advice. The Volga is being built as the most terrible. Looking for a bridge from GS. Thank you very much.All Glory to you
Vijaya
Post by Vijaya »
gearbox from GS450h found.Now I'm looking for the driveshaft .But where do I get an electric motor and powerful batteries?
zilion
Post by zilion »
"gearbox from GS450h" is the electric motor, but check if you have with oil pump -it's commonly removed.
If you have one -change bearings.
https://openinverter.org/wiki/Motors
Vijaya
Post by Vijaya »
Thank you, dear Zilian.I wanted to say that I found a differential on the rear wheel for good speed. Now I'm looking for a driveshaft combined with a good gearbox and a separate good engine.
Been thanked: 1136 times
UStas
Post by UStas »
Let me switch to russian.
Вадим, есть ряд русскоязычных форумов по электротранспорту :
https://electroavtosam.com.ua/forums/
https://electrotransport.ru/ussr/index.php
Буду рад если заглянешь в мою тему про переоборудование Опель Тигра, ссылка ниже.
Сами запчасти по доступным ценам можно искать на сайте farpost.ru
Например двигатель Outlander MGR я купил там за 5000 руб - $72 !!!
Но чтобы оживить инвертор конечно нужны будут "мозги" от Демьена с этого сайта.
Вариантов много:
Можно купить готовую настроенную плату (дорого, но меньше всего хлопот),
Можно купить частично собранную плату и допаять все необходимое самому (средняя цена, но нужно иметь навыки пайки и прошивки MCU),
Можно воспользоваться документацией в свободном доступе и заказать изготовление плат в Китае (выгодно если делать несколько проектов).
