Toyota Prius Gen3 Board
Prius Inverter
Control Board
Development History
Vendors
Support
Inverter Model Numbers
| G9200-47141 | Auris 2012, RHD | ||||||
| G9200-47140 | Prius 2010 | F1759-47041 01 | |||||
| G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
| G9200-52010 | Yaris | F1759-52010 04 | F1789-52010 | 154x143mm | https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828 | ||
| G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com |
Soldering The Breakout Board
I started with the breakout board. Soldering the Ampseal connector the the board, the board instructs which side to fit it.
Next flip it over and put the lock connector on, notch upwards, the version of the board I have is marked incorrectly with the notch at the bottom.
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
DC-DC Converter
12v Battery Connection
[Add details]
[Add battery connection details]
Ampseal Connector
Connecting Resolver
