Isabellenhütte Heusler
IVT-S Current and voltage sensors for battery management systems (here)
IVT-S Datasheet (here)
IVT-S Arduino Library Files from EVTV (here). Note: it's been reported that the header file ISA.h contains several errors.
IVT-S uses Molex connectors which can be purchased from RS, Digi-Key and Mouser (among others). Despite what it says in the Isabellenhütte data sheet, these are the correct part numbers:
Description | Molex part number | Mouser part number |
2-pin DuraClik header | 502351-0200 | 538-502351-0200 |
4-pin DuraClik header | 502351-0400 | 538-502351-0400 |
DuraClik crimp terminal | 50212-8100 | 538-50212-8100 |
By default, the IVT-S will put a current reading on the CAN bus at 1Mb/s every 20ms. You can read the data with your favourite CAN bus sniffer or build your own with an Arduino Uno and CAN bus shield
