Toyota Prius Gen3 Board
Revision as of 18:14, 8 June 2020 by Bigpie (talk | contribs) (Start of Assembly instructions for V1C of the board.)
Prius Gen3 Control Board v2
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47140 Prius 2010 F1759-47041 01
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
G9200-52010 Yaris F1759-52010 04 F1789-52010 154x143mm https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828
Assembly Instructions (V1C)
Soldering
I started with the breakout board. Soldering the Ampseal connector the the board, the board instructs which side to fit it.
Assembly Notes
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes.
There are some parts that have to be changed and populated to get the partly build board working.
You need for the board 3 resistors 1kOhm, 1 resistor 1,2kOhm, 2 LED red and 1 elcap 35V 330µF.
  • First you have to desoldering the diodes D1, D2 and D3 to change the polarity and resolder them.
  • R52 is missing, 1kOhm resistor.
  • Change R89 from 1,5kOhm to 1,2kOhm to correct tmphs, it is 20°C to high.
  • C26 has to change for an elcap with higher voltage, so use 330µF 35V.
  • Change R38 from 330Ohm to 1kOhm so that LED1 is not so bright.
  • LED2 and LED3 are missing, for LED2 change R39 from 330Ohm to 1kOhm.
With the new Firmware v4.85R customized by Damien you don't need to change the hardware as explained in the past, see at his post https://openinverter.org/forum/viewtopic.php?f=14&t=488&start=60#p11328
For mounting in the original case you have to remove some plastic from the carrier of the current sensors below the battery input for the PriusG3_V1b board.
For the Yaris inverter you have to remove additionally some of the mounting points below the board.
If you want to reuse the connectors from the original board, for the Yaris the connector from the MG2 current sensor plug and the HV interlock plug is different to the Prius, so you have to get extra connectors or you can only use one connector for the current sensor and no connector for HV interlock, which is usually sufficient. It is not a fun to desolder the connectors,especially the 50 pol connector, and if you have not some experience in soldering it is better to get them new.
Some of the points are as well for the other prius boards noteworthy.
Source Documentation:
Damien's Prius Gen3 v2 Github
