Toyota Prius Gen3 Board
Prius Inverter
- Respectable performance. Rated for 50kW output, but tested (Gen2, Gen3 suspected to be similar) to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
Control Board
Development History
Vendors
Support
Inverter Model Numbers
| G9200-47141 | Auris 2012, RHD | ||||||
| G9200-47140 | Prius 2010 | F1759-47041 01 | |||||
| G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
| G9200-52010 | Yaris | F1759-52010 04 | F1789-52010 | 154x143mm | https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828 | ||
| G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com |
Assembly Notes
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes.
There are some parts that have to be changed and populated to get the partly build board working.
You need for the board 3 resistors 1kOhm, 1 resistor 1,2kOhm, 2 LED red and 1 elcap 35V 330µF.
- First you have to desoldering the diodes D1, D2 and D3 to change the polarity and resolder them.
- R52 is missing, 1kOhm resistor.
- Change R89 from 1,5kOhm to 1,2kOhm to correct tmphs, it is 20°C to high.
- C26 has to change for an elcap with higher voltage, so use 330µF 35V.
- Change R38 from 330Ohm to 1kOhm so that LED1 is not so bright.
- LED2 and LED3 are missing, for LED2 change R39 from 330Ohm to 1kOhm.
When using the FOC firmware you have to change the control lines on the board between PWM2 and PWM3 because the current sensors are at L1 and L3 and the software expect the sensors at L1 and L2. You have to cross the resistors R51 and R52 as well as R54 and R55, so that MG2_PWM2 control MG2_C and MG2_PWM3 control MG2_B.
For the sine version I don't know if it is needed.
For mounting in the original case you have to remove some plastic from the carrier of the current sensors below the battery input for the PriusG3_V1b board.
For the Yaris inverter you have to remove additionally some of the mounting points below the board.
If you want to reuse the connectors from the original board, for the Yaris the connector from the MG2 current sensor plug and the HV interlock plug is different to the Prius, so you have to get extra connectors or you can only use one connector for the current sensor and no connector for HV interlock, which is usually sufficient. It is not a fun to desolder the connectors,especially the 50 pol connector, and if you have not some experience in soldering it is better to get them new.
Some of the points are as well for the other prius boards noteworthy.
Source Documentation:
