Lexus GS450h Drivetrain
Revision as of 22:19, 16 May 2020 by RE3Rotor (talk | contribs)
The Lexus GS450h VCU is an open source project to repurpose 2006-2012 Lexus GS450h inverters for DIY EV use. It consists of a circuit board and programming that communicates with the original logic board in the inverter and allows independent control of it without communicating with a GS450h ECU.
Note that the Toyota Camry hybrid (US market) uses a similar inverter with the same logic board, which is functionally identical to the GS450h unit.
GS450h Inverter
Toyota Camry Inverter external connector
GS450h internal inverter connections
  • 2 high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps.
  • A boost module to boost the 288v battery pack up to 650v
GS450h Converter
A buck/boost converter lives within the inverter housing, originally this is used to step up the 288V battery pack in the GS450h to the 650V for use in the inverter. For those using a 600+V battery pack, this converter can be used to step the voltage down to a more reasonable level to interface with charfgers, DCDC converters, heaters, AC compressors, and other components which can be found in "regular" EV's (Tesla, Leaf, Volt, etc).
GS450h Transmission
GS450h inverter
For technical analysis of this transmission, see pages 46 onwards of this document: https://www.osti.gov/servlets/purl/947393
The input shaft on the transmission has 21 splines, with a 28mm major diameter. It is believed that there are several Toyota clutches which will have this in their centre. The original GS450h flywheel and coupler also contains the appropriate slined centre, of course.
GS450h shift position sensor
  • It is recommended to purchase one which has the electric oil pump fitted - these are a costly item as the bearings in them often fail, in some cases they cost more than the transmission.
Transmission is tapered quite heavily, the width and height is closer to 25cm after the bellhousing, but hard to gauge due to various outcropping parts (motor cables, oil pump, PRNDL selector, etc)
Oil Pump
The Oil Pump
Black is PWM in from your controller.
Oil Pump 2
Brown is feedback from the oil pump. It's PWM. Do what you want with this or leave it disconnected.
The fat blue wire is 12V power. The oil pump uses around 50A Max. So plan for that. Add your own relay to stop it draining your battery while the car is off.
The metal case is the ground.
The PWM for this is weird, it's not just 0-100. IIRC it is 0% at both ends, and rises to 100% near the middle, then back down again. This is just based on the sound of the pump with no load, so needs more testing to find the real values.
Wiring Harness Connectors
Inverter Connectors
Connector Part No. Location
Inverter interface connector (A62) 90980–12630 Black connector on the side of the inverter. This connector is not sold anywhere to our knowledge.
A good alternative to this, otherwise difficult to obtain, connector is to replace the receptacle/header with the following parts from Molex:
Image Part No. Item Quantity
064320-1301 CMC wire cap 1
064323-1039 CP terminal 4
064323-1029 CP terminal 32
064325-1010 CMC plug 8
064325-1023 CMC plug 4
Connector - A55 Oil Pump Motor Controller 90980–12483
Transmission Connectors
ECT Solenoid (E83) Sumitomo 6189-1092 Located on the left hand side of the transmission above the oil pan.
Shift Lever Position Sensor (E80) Sumitomo 90980-12362 Located on the right side of the transmission next to the shift lever inhibitor switch.
MG1 & MG2 Resolver(s) (E81 & E82) Sumitomo 6189-1240 Located on the left side of the transmission by the bell housing.
HVECU -> Oil Pump Controller (A52) Single large (7-way) connector on the side of the oil pump controller
Oil pump
Control Board
An open-source VCU, designed by Damien Maguire, can be purchased as both partially populated and fully populated and tested boards on his website:
GS450h transmission and oil pump temperature sensor
Lexus GS450H VCM Fully Built and Tested
  • 33472-2002 (Left side, grey in colour)
  • 33472-2001 (Right side, black in colour)
  • 33012-2002 (Crimp terminals)
Development History
Vendors
There are currently no vendors who offer support on any aspects of the GS450h VCU.
Support
