Volvo Power Steering Pump
Revision as of 21:27, 23 February 2026 by Marc986 (talk | contribs) (Added information about control connector in use on some pumps)
Part Numbers and Versions
Part Numbers[1]
Part Number Vehicle Used in Comment
30636927 2004-2013 C30 C70 V50 S40 unverified
31202520 2004-2013 C30 C70 V50 S40 unverified
36000075 2004-2013 C30 C70 V50 S40 unverified
36000116 2004-2013 C30 C70 V50 S40 unverified
36000772 2004-2013 C30 C70 V50 S40 unverified
36000801 2004-2013 C30 C70 V50 S40 unverified
36001211 2004-2013 C30 C70 V50 S40 unverified
36001485 2004-2013 C30 C70 V50 S40 unverified
36002698 2004-2013 C30 C70 V50 S40 unverified
36050678 2004-2013 C30 C70 V50 S40 unverified
8603041 2004-2013 C30 C70 V50 S40 unverified
8603274 2004-2013 C30 C70 V50 S40 unverified
Electrical Connection
Input signals, start and stop conditions described in S40 service manual[2]
The harness for the motor supply can be bought completely (Volvo Part Number: 30775461 [3]) or just the connector. There is connector kits available online (avoid the pig-tail version as the cable is way undersized. Link)
2011 Volvo S40 T5 Pump connectors
Connector A (Power)[4]
Pin Number Cable Color Function Comment
1 Red Permanent +12V for Motor Fused with 80A fuse (F2)
2 Black GND
Volvo Part Numbers
Part Part Number Comment
Housing 31266849[5] Not verified, possibly different plug?
Housing 30728420[6] Not verified
OEM (Yazaki) Part Numbers
Housing 7283-2918-10[7] Also in black, P/N 7283-2918-30
Terminals 7116-3250[8] For 8mm2 wire
Wire Seals 7158-3610-80[9] For 8mm2 wire
Note: Some later Volvo models use a similar variant of this pump which has a different shaped (smooth housing body) Connector A. Not known if the CAN protocol is different.
Connector B (Control)[4]
1 Grey-Blue Ignition +12V for Control Fused with 10A fuse (F53).
2 CAN-L
3 CAN-H
A visual guide of the pinout can be found on this MaxxECU online help page
Volvo Part Numbers
Connector 31346135[10] Not verified
Housing 7283-8730-30[11]
Terminals 7116-1680-02[12]
Wire Seals 7157-3951-60[13]
At least some pumps use a different control connector:
Housing 7283-8977-30
Terminals 2.8x0.8 female see ref[14]
Wire Seals see ref[14]
CAN Bus Control
If it doesn't receive CAN messaging then the pump will run in "limp mode" at 75% of full speed.[15]
The CAN bus protocol has been reverse engineered in the RusEFI forum[16] and a LUA script example exists[17]
Alternatively, there is an implementation using Arduino code[18]
Mechanical Properties
Approx. 12" x 7" x 7" (305mm x 178mm x 178mm)
Fittings
  • High pressure side (pump supply/outlet): M16x1.5 (you can use adapters like this one: https://www.ebay.de/itm/192079081475)
  • Low pressure side (pump return/inlet) is just a hose. The fitting on the reservoir is likely 10mm (3/8").
Mounting Bracket
WillFab Motorsport (WFM) produces a universal fit bracket for this pump. Available here and here.
Fluid
Pentosin CHF 202 is spec'd in the Volvo manual.
  1. https://rusefi.com/forum/viewtopic.php?p=45946#p45946
  2. https://www.volvo-forums.com/attachments/s40my2005_suspensionsteering-pdf.7233/
  3. https://usparts.volvocars.com/p/Volvo_2007_C30-24l-5-cylinder/Wiring-Harness-Cable-Harness-Power-Steering-Pump-Electrohydraulic-Power-Steering-Service-Solution-Servo-Pump/42906949/30775461.html (Backup: )
  4. 4.0 4.1 Volvo C30 2007 Schematic, TP39103202
  5. https://usparts.volvocars.com/p/Volvo_2007_C30-24l-5-cylinder/Receptacle-Housing-Cable-Harness-Engine-Component-Parts-Electrical-Power-Steering-Module-EPS/42815694/31266849.html
  6. https://usparts.volvocars.com/p/Volvo_2011_S60-30l-6-cylinder-Turbo/Receptacle-Housing-Cable-Harness-Engine-Compartment-Component-Parts-Connector-Control-Module-Power-Steering-EHPS-Electrical-Power-Steering-Module-EPS-/42878531/30728420.html
  7. https://connector.yazaki-group.com/cgi-bin/english/detail.cgi?part_id=7283-2918-10
  8. https://connector.yazaki-group.com/cgi-bin/english/detail.cgi?part_id=7116-3250
  9. https://connector.yazaki-group.com/cgi-bin/english/detail.cgi?part_id=7158%2D3610%2D80
  10. https://usparts.volvocars.com/p/Volvo_2007_C30-24l-5-cylinder/Receptacle-Housing-Electric-Power-Steering-EPAS-Electrical-Power-Steering-Module-PSCM/65250641/31346135.html
  11. https://connector.yazaki-group.com/cgi-bin/english/detail.cgi?part_id=7283-8730-30
  12. https://connector.yazaki-group.com/cgi-bin/english/detail.cgi?part_id=7116%2D1680%2D02
  13. https://connector.yazaki-group.com/cgi-bin/english/detail.cgi?part_id=7157%2D3951%2D60
  14. 14.0 14.1 https://connector.yazaki-group.com/cgi-bin/english/search.cgi?search_kbn=series&series_cd=YESC09_2.8X0.8WP
  15. https://www.corral.net/threads/volvo-electric-power-steering-conversion-full-write-up.2499503/page-4?post_id=18735339#post-18735339
  16. https://www.rusefi.com/forum/viewtopic.php?f=4&t=2329
  17. https://github.com/rusefi/rusefi/blob/master/firmware/controllers/lua/examples/Volvo-electric-power-steering-pump.txt
  18. https://github.com/NMSTEC/Volvo_EPS_FREE
