GM Electronic Shift Lever
Revision as of 04:40, 24 June 2025 by Dczechowski (talk | contribs) (Correcting mislabeled pins)
Picture: https://dz310nzuyimx0.cloudfront.net/strapr1/c9b64e71dbbc2662c1a8b1a4cb340622/93cd9f9925f7f4cb34c35b989acf53b2.png
About
This is a complete directional switch (P-R-N-D) with indication available from ACDelco for less than $100.
It is GM part number 13564966 (formerly: 13563947) and 13559765 (formerly 13552390, 13554747).
Details
This part is designed around a Melexis ML90378 Triaxis Hall Effect Position sensor and built into a steering column lever module.
It uses a PWM or SENT protocol to continuously provide data of the position of the lever.
Pin Out
Connector: https://da8h1v3w8q6n5.cloudfront.net/mi34/inventory/FB0465/R02949995_5.jpg
Pin Description
1 (Top Row, Left Most) Output 1
2 Vss 1
3 Vss 2
4 Vdd Supply 2
5 ??
6 (Bottom Row, Left Most) Vdd Supply 1
7 GND?
8 Output 2
X (No Pin)
10 ??
