Builds
Revision as of 10:29, 7 February 2025 by CalebMo44 (talk | contribs) (Entered Damien's E39 Land Yacht entry)
This page contains a selection of actual, completed (or nearly completed) builds that demonstrate the use of components, software, and methods of the Open Inverter community. The builds listed identify the vehicles, components, and specs to assist users who are looking for an example of a successful installation of a part (or combination of components). The below page is organized by drivetrain. More examples can be found by searching the Forum, specifically the Projects section.
Nissan Leaf
Toyota GT86 by User/Builder: Zapatero
(January 2020 specs and stats unless otherwise noted)
Motor
2014 Nissan Leaf
*2022 UPDATE* 160kW Inverter, CAN controlled
Originally a Nissan Leaf Inverter with Johannes Huebner main board, fully CAN-bus controlled
Batteries
*2021 UPDATE* 30kWh pack (from pro-LOX?)
Originally a 24kWh pack (48 modules, 96 cells) from 2012 Leaf
BMS
Orion 2, fully CAN-bus controlled
ECU
GT86, Arduino based replacement ECU for CAN-communication from Geraldjustprojects.com
Chargers
2x ELTEK Valere 3.3kW Chargers in parallel, fully CAN-bus controlled (6.6kW slow charge)
CHAdeMO Fast charging Socket and control box. Controlled by Orion BMS 2.
DC-DC
First-gen Tesla Model S converter
Estimated Power
140kW, 400Nm torque
Range
200 km (124.27 mi)
Fast Charging
20-80% in 20 Minutes
0-100
6.7 Seconds (kph or mph?)
Air Conditioning
400V AC compressor, 12V activated by ECU with all parameters as AC pressure, AC switch
Heating
1.2kW PTC heater from Subaru Outback
Weight (in kg)
Before After
Front 710 680
Rear 560 660
Total 1270 1340
Weight Ratio
Before After
Front 56% 51%
Rear 44% 49%
Links: Forum Project Thread Webpage YouTube Video
Lexus GS450h
BMW E39 (The Land Yacht)
by Builder/User: Jack Bauer aka Damien Maguire
In four+ phases and iterations over more than a decade.
Phase I (2012-2018)
Motor
DC motor (forklift)
Batteries
CALB CA180FI cells
60 cells, 192V, 36kWh
Phase II (2018-2020)
Motor
AC induction motor
140V, Liquid Cooled
? Liquid Cooled
Charger
Tesla Gen2 10kW
Ancillary
Opel Zafira power steering pump
E39 transmission cooler to radiator
Phase III (2020)
Motor
Siemens 1PV 5135 induction motor
Gearbox
E39 530D
Inverter/Converter
Prius Gen3
Batteries
9kWh 360V pack from 2018 BMW 740e Hybrid
Ancillary
V5 board in Tesla charger
HV junction box with ISA shunt & Lexus GS450h VCU to control charger and allow pre-charge
CAN control to all systems
Phase III.5 (2021)
Battery
Added a 24kWh pack from Nissan Leaf in parallel with previously installed BMW 740e Hybrid pack
Phase IV (Late 2022 - Early 2023)
Motor
Lexus GS450h Transaxle
Lexus GS450h
Ancillary
Gearbox swap from Manual to Automatic (E39 shifter)
Stats (Dyno test 2023)
225hp @ 120kph in high gear
140.5hp @ 63kph in low gear (NOTE: low gear test not successful/accurate due to wheel torque on dyno roller)
Ancillary
360V nominal
Zombieverter VCU with version 1.11 software
CHAdeMO fast charge
Links: Youtube page Youtube playlist of this build (starts on vid 21 of Phase I for some reason) Damien's Website
