Builds
Revision as of 09:38, 7 February 2025 by CalebMo44 (talk | contribs) (Beginning a new entry.)
This page contains a selection of actual, completed (or nearly completed) builds that demonstrate the use of components, software, and methods of the Open Inverter community. The builds listed identify the vehicles, components, and specs to assist users who are looking for an example of a successful installation of a part (or combination of components). The below page is organized by drivetrain. More examples can be found by searching the Forum, specifically the Projects section.
Nissan Leaf
Toyota GT86 by User/Builder: Zapatero
(January 2020 specs and stats unless otherwise noted)
Motor
2014 Nissan Leaf
*2022 UPDATE* 160kW Inverter, CAN controlled
Originally a Nissan Leaf Inverter with Johannes Huebner main board, fully CAN-bus controlled
Batteries
*2021 UPDATE* 30kWh pack (from pro-LOX?)
Originally a 24kWh pack (48 modules, 96 cells) from 2012 Leaf
BMS
Orion 2, fully CAN-bus controlled
ECU
GT86, Arduino based replacement ECU for CAN-communication from Geraldjustprojects.com
Chargers
2x ELTEK Valere 3.3kW Chargers in parallel, fully CAN-bus controlled (6.6kW slow charge)
CHAdeMO Fast charging Socket and control box. Controlled by Orion BMS 2.
DC-DC
First-gen Tesla Model S converter
Estimated Power
140kW, 400Nm torque
Range
200 km (124.27 mi)
Fast Charging
20-80% in 20 Minutes
0-100
6.7 Seconds (kph or mph?)
Air Conditioning
400V AC compressor, 12V activated by ECU with all parameters as AC pressure, AC switch
Heating
1.2kW PTC heater from Subaru Outback
Weight (in kg)
Before After
Front 710 680
Rear 560 660
Total 1270 1340
Weight Ratio
Before After
Front 56% 51%
Rear 44% 49%
Links: Forum Project Thread Webpage YouTube Video
Lexus GS450h
BMW E39 (The Land Yacht)
by Builder/User: Jack Bauer aka Damien Maguire
In four+ phases and iterations over more than a decade.
