Zombieverter programing
Revision as of 00:25, 1 February 2025 by Bratitude (talk | contribs) (Created page with ">Use this bootloader: https://github.com/jsphuebner/stm32-CANBootloader '''GD variant:''' ''Status as of November 20 2021'' ''Early boards fitted with the GigaDevices '''GD32F107''' aka "GD chip" require different firmware routines than '''STM32F107''' equipped boards. See this [https://openinverter.org/forum/viewtopic.php?p=33758#p33758 Zombieverter VCU Support Thread forum post]'' ''The GigaDevices `[https://www.gigadevice.com/products/microcontrollers/gd32/arm-c...")
GD variant:
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
Initializing an ISA Shunt
Under Comms in the web interface, there is now an ISAMode option. By default its in "Normal" (Off on Rev 2). If you want to initialize a new shunt, connect it up, power on the shunt and vcu, select "Init" (On on Rev 2), hit save parameters to flash. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway). The shunt will initialize. Select ISAMode "normal" (Off on Rev 2), save to flash again and reboot again. The shunt should now be up and running. If the shunt doesn't initialise correctly, separate the shunt and VCU supplies and power cycle the VCU two or three seconds after the shunt power is cycled. This has fixed an initialise issue for a number of ISA shunts and possibly requires a VCU code fix that delays the initialising for a few seconds to allow the shunt to power up.
