Tesla Model 3 Rear Drive Unit
Revision as of 17:58, 20 December 2024 by Tom91 (talk | contribs) (Categories)
External Documentation
Tesla Model 3 Rear Drive Unit Hacking (forum thread)
https://github.com/damienmaguire/Tesla-Model-3-Drive-Unit (Hardware and reverse engineering details)
https://github.com/jsphuebner/stm32-sine/tree/tesla-m3-gate-driver (STM32 "modboard" firmware dev. branch)
Part Numbers
Part Number Description Max Current Cars
1120970-00-F (ASY,M3,3DU,REAR,IGBT) - original RWD and/or "binned" Perf 800A Model 3
1120980-00-G (ASY,M3,REAR 3DU,MOSFET,GLOBAL) - early AWD motor 800A Model 3 / Model Y
1120990-00-G (ASY,M3,REAR,MOSFET-LC,GLOBAL) - newer AWD motor 600A Model 3 / Model Y
1120990-00-H (ASY,M3,REAR,MOSFET-LC,GLOBAL) - newer AWD motor 2021 with few hints on it's actual existence ([2]) ???A Model 3 / Model Y
1120990-00-J (ASY,M3,REAR,MOSFET-LC,GLOBAL) - current (Jan 2022) AWD (EPC [3]) ???A Model 3 / Model Y
1521365-00-B (ASY, REMAN, 3DU-Rear 800 MOSFET) - Remanufactured 1120980-00-G 800A Model 3 / Model Y
1521487-00-A (ASY, REMAN, 3DU-REAR 630 MOSFET) - Remanufactured 1120990-00-G 600A Model 3 / Model Y
[1] Details from https://www.reddit.com/r/teslamotors/comments/ioat3d/rear_motor_efficiency_improvements_980_vs_990/.
[2] https://www.ebay.de/itm/185026392386
[3] https://epc.tesla.com/en/catalogs/138/categories/10030/subcategories/42427
Connectors and Pinouts
Label Description Pins Compatible Plugs Link
X090 Inverter connector 30 Toyota 90980-12712 (Sumitomo 6189-6987)
? Rotor Shaft Resolver 10 (8 connected) TE Connectivity 1-2282337-1
? Oil Pump 3 TE Connectivity 1-1718644-1
? HV connector 2 TE Connectivity HC-STAK 90° 2840900-1 TE Product Application
Power Figures
Taken from tesla:
RWD Variant
Voltage: 350v
Max Power: 239 KW @ 5525 rpm
Max Torque: 420 nm @ 325-5200 rpm
AWD Variant
Voltage: 335v
Max Power: 203 KW @ 6700 rpm
Max Torque: 330 nm @ 325-5200 rpm
Performance Variant
Voltage: 320v
Max Power: 219 KW @ 5075 rpm
Max Torque: 420 nm @ 325-4800 rpm
Mechanical Specification
Max rotor speed: 18,447 rpm
Input shaft gear: 31 teeth
Counter shaft input: 81 teeth
Counter shaft output: 24 teeth
Ring gear: 83 teeth
Gearbox Ratio: (81/31) * (83/24) = 9.036
Details from https://www.youtube.com/watch?v=SRUrB7ruh-8.
Inverter Components
Manufacturer Part No Description Quantity Datasheet
ST ST GK026 SiC FET drive transistors 24 https://www.st.com/en/power-transistors/sctw100n65g2ag.html (?)
ST STGAP1AS Gate Drivers 6 https://www.st.com/en/power-management/stgap1as.html
ST STD46P4LLF6 P-channel Power MOSFET 40V 6 https://www.st.com/en/power-transistors/std46p4llf6.html
Infineon 3N0408 N-channel Power Transistor 6
TI TMS320F28377DPTPQ C2000 Delfino MCU 1 TMS320F2837xD Dual-Core Microcontrollers Datasheet
TMS320F2837xD Dual-Core Microcontrollers Technical Reference Manual
On Semi TCA0372BDW Resolver amplifier 1 https://www.onsemi.com/pdf/datasheet/tca0372-d.pdf
TI LMV844 Temperature sensor amplifier 1 https://www.ti.com/lit/gpn/lmv844
Microchip 25LC256E EEPROM 1 http://ww1.microchip.com/downloads/en/DeviceDoc/20005715A.pdf
TI SN65HVD1040A CAN Transceiver 2 https://www.ti.com/lit/ds/symlink/sn65hvd1040a-q1.pdf
NXP TJA1021 LIN Transceiver 1 https://www.nxp.com/docs/en/data-sheet/TJA1021.pdf
Broadcom ACPL-C87BT-000E DC HV sense 1 https://docs.broadcom.com/docs/AV02-3564EN
Infineon TLF35584QVVS2 DC-DC Power and system watchdog 1 https://uk.farnell.com/infineon/tlf35584qvvs1xuma2/multi-volt-pwr-supply-ic-40-to/dp/3155085
TDK VGT22EPC-222S6A12 DC-DC Transformer (gate drive?) 1 https://product.tdk.com/en/search/transformer/transformer/gate-drive/info?part_no=VGT22EPC-200S6A12
Details from https://www.youtube.com/watch?v=l6dV2re3rtM.
[Category:Gearbox]]
Oil specification
There are two variants of rear drive unit in terms of oil. One where the oil is also inside the motor and one where it isn't. Where the gear oil is also inside the motor the oil will be black in colour. In this case FUCHS BluEV EDF 7005 oil is required, not using this oil will degrade the motor and cause failure in the long term.
