Toyota Prius Gen2 Board
The Toyota Prius Gen2 Board is an open source project to repurpose 2004-2009 Toyota Prius inverters for DIY EV use. It consists of a circuit board and programming that replaces the original logic board in the inverter and allows independent control of it without communicating with a Prius ECU.
Prius Inverter
- Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
- 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
How To Use
The control board utilizes the Blue Pill (link?) microcontroller, and takes advantage of the OpenInverter.org software (link?) for control.
Wire Connections
Control Board Pinout:
| Pin # | Designation | Description |
| TB1-1 | 12v-in | Primary 12v supply from ignition on |
| TB1-2 | GND | Primary ground connection to 12v negative. All grounds are common |
| TB1-3 | 5v VCC | 5V supply from board for use with throttle pot or hall pedal |
| TB1-4 | Throttle In | 0-5v variable voltage input from throttle pedal or pot |
| TB1-5 | Regen In | 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor |
| TB1-6 | GND | |
| TB1-7 | Brake In | 12v digital input from brake light switch. |
| TB1-8 | Start In | 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used. |
| TB1-9 | For In | 12v digital input commands motor to run in forward direction |
| TB1-10 | Rev In | 12v digital input commands motor to run in reverse direction |
| TB3-1 | +12v VCC | 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it). |
| TB3-2 | GND | Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it). |
| TB3-3 | Phase U |
| TB3-4 | Phase Y | Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive |
| TB3-5 | Phase W | Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive |
| TB3-6 | Current U | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-7 | Current Y | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-8 | MG2 Enable | Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter |
| TB3-9 | MG2 Fault | Connect to MFIV for MG2 or GFIV for MG1 |
| TB3-10 | DC Bus | Connect to inverter VH to measure DC link voltage |
| TB2-1 | +5V VCC | 5v output to encoder for induction motor |
| TB2-2 | ENCA In | Encoder input A |
| TB2-3 | ENCB In | Encoder input B |
| TB2-4 | GND | Encoder ground |
| TB2-5 | HS Temp | Heatsink temp sensor input |
| TB2-6 | MOT Temp | Motor temp sensor input |
| TB4-1 | GND | Common ground |
| TB4-2 | Main Con | Main HV contactor control low side switch |
| TB4-3 | Precharge | HV precharge contactor control low side switch |
| TB4-4 | +12 V VCC | Spare 12v output |
| TB4-5 | CAN L | Can bus low signal |
| TB4-6 | CAN H | Can bus high signal |
32-pin Prius Inverter Pinout:
| Pin # | Designation | Description | Wire Color |
| 1 | NC | Not connected | |
| 2 | GIVA | MG1 Phase Current V | Example |
| 3 | GIVB | MG1 Phase Current V | Example |
| 4 | GUU | MG1 PWM U - Speed Signal Wave | Example |
| 5 | GVU | MG1 PWM V - Speed Signal Wave | Example |
| 6 | GWU | MG1 PWM W - Speed Signal Wave | Example |
| 7 | MIVA | MG2 Phase Current V | Example |
| 8 | MIVB | MG2 Phase Current V | Example |
| 9 | MUU | MG2 PWM U - Speed Signal Wave | Example |
| 10 | MVU | MG2 PWM V - Speed SIgnal Wave | Example |
| 11 | MWU | MG2 PWM W - Speed Signal Wave | Example |
| 12 | VH | Inverter Capacitor Voltage | Example |
| 13 | CPWM | Boost converter PWM switch signal | Example |
| 14 | GSDN | MG1 Shutdown | Example |
| 15 | VL | Boost converter input voltage | Example |
| 16 | GINV | Inverter Ground | Example |
| 17 | NC | Not connected | |
| 18 | GIWA | MG1 Phase Current W | Example |
| 19 | GIWB | MG1 Phase Current W | Example |
| 20 | CT | Boost converter temperature sensor | Example |
| 21 | GIVT | MG1 Inverter Temperature | Example |
| 22 | GFIV | MG1 Inverter Fail | Example |
| 23 | MIWA | MG2 Phase Current W | Example |
| 24 | MIWB | MG2 Phase Current W | Example |
| 25 | MSDN | MG2 Shutdown | Example |
| 26 | MIVT | MG2 Inverter Temperature | Example |
| 27 | MFIV | MG2 Inverter Fail | Example |
| 28 | OVH | Overvoltage | Example |
| 29 | CSDN | Boost converter shutdown signal | Example |
| 30 | FCV | Boost converter fail signal | Example |
| 31 | OVL | Boost converter over voltage signal | Example |
| 32 | GCNV | Boost converter ground | Example |
