Mitsubishi Outlander Rear Drive Unit
Property | Value | Source |
Device | Combined Motor, Gearbox and Rear Differential | |
OEM | Mitsubishi | |
Type | AC Motor 10 Pole 3 Phase synchronous perm magnet brushless | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html
https://openinverter.org/forum/viewtopic.php?f=19&t=325&start=30 |
Manufacturer | Meidensha | https://www.meidensha.com/products/case/prod_05/prod_05_01/prod_05_01_01/prod_05_01_01_01/1210605_4260.html |
Suppliers | Ebay, Second Life EV Batteries | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html |
Max RPM | 9600RPM | |
Mechanical Mounting | 6x M10 Bolt front face flange (all in same plane)
3x M12 Bolt Rear Flange (all in same plane) used for bush mount on Outlander |
Author experience |
Shaft Type | 20.02mm 18 splines, ~60mm long
Resolver | SIN COS - P/N C69600/TS2239N484E102
Cooling | Water/glycol cooling (Blue on Outlander) | Author experience |
Weight | 42kg | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html |
Power To Weight Ratio | 70kW Motor: 1.66 kW/kg | |
Diff Ratio | 7.065:1 | http://www.mitsubishi-motors.com.hk/uploads/file_1465376705.pdf |
Motor Part Numbers | 9499D146 (01/08/13 > 30/09/17) GG2W 2000 plug in hybrid | Mitsubishi Outlander Online Parts Catalogue |
Motor Part Numbers | 9411A078 (01/05/18 > ) GG2W 2000 plug in hybrid | Mitsubishi Outlander Online Parts Catalogue |
Motor Part Numbers | 9411A078 (01/05/18 >) GG3W 2400 plug in hybrid | Mitsubishi Outlander Online Parts Catalogue |
Example Ebay Listing:
Description
The Mitsubishi Outlander PHEV (Plug-in Hybrid) uses 3x AC motor/generators - 2 in the front gearbox (One is designated as a generator) and 1 in the rear. The rear motor appears to be the more powerful of the 3, and it is coupled to a rear differential unit which is mounted underneath the vehicle. The Rear differential has female driveshaft splines and a ratio of 7.065:1. The motor is driven by a dedicated rear inverter unit, and the combined system appears to have different power ratings in different model years. The whole unit could lend itself well to rear engined/rear wheel drive EV conversion applications - e.g. Toyota MR2, VW Beetle, rear engined Porsches, Lotus. The Motor can also be easily decoupled from the Gearbox/Differential unit and with an adaptor plate and coupling could be used on either Front wheel drive applications, or Front engined, rear wheel drive. There are already some examples of the drive being used with the OpenInverter, and also with the OEM motor inverter.
Power Rating
Model Years | Motor Power | Motor Torque | Part Number |
TBC - TBC | 50 kW | TBC | Y61 |
TBC - 2018 | 60 kW | 195Nm Peak | Y61 |
2018 - | 70 kW | 195Nm Peak | Y61 |
Mitsubishi/FUSO part numbers include 9411A078, 9499D132, 9499D146, and MEIDEN part numbers include F1E1A2B5Z
Connectors:
HV: 3x 3 phase lug connections with HV gland plate
R12 - 35,5R Black, White
S13 - 86,4R Green, Red
S24 - 78,5R Yelow, Blue
The polarity of all six wires have to be correct in order for the motor to work.
Pinout of Resolver/Temperature Sensor connector:
Pin | Label | Description |
1 | N/A | Not used |
2 | TG2 | Temperature sensor 2 ground |
3 | TG1 | Temperature sensor 1 ground |
4 | RGND | Resolver ground |
5 | S4 | Cos connection |
6 | S3 | Sin connection |
7 | R2 | Exciter connection |
8 | N/A | Not used |
9 | TH2 | Temperature sensor 2 |
10 | TH1 | Temperature sensor 1 |
11 | N/A | Not used |
12 | S2 | Cos connection |
13 | S1 | Sin connection |
14 | R1 | Exciter connection |
Vehicle Wiring Diagrams
