Lexus GS450h Drivetrain
Revision as of 21:28, 15 February 2020 by Xp677 (talk | contribs) (→GS450h Converter)
GS450h internal inverter connections
The Lexus GS450h VCU is an open source project to repurpose 2006-2012 Lexus GS450h inverters for DIY EV use. It consists of a circuit board and programming that replaces the original logic board in the inverter and allows independent control of it without communicating with a GS450h ECU.
GS450h Inverter
  • 2 high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps.
  • A boost module to boost the 288v battery pack up to 650v
GS450h Converter
A buck/boost converter lives within the inverter housing, originally this is used to step up the 288V battery pack in the GS450h to the 650V for use in the inverter. For those using a 600+V battery pack, this converter can be used to step the voltage down to a more reasonable level to interface with charfgers, DCDC converters, heaters, AC compressors, and other components which can be found in "regular" EV's (Tesla, Leaf, Volt, etc).
GS450h Transmission
GS450h inverter
The input shaft on the transmission has 21 splines, with a 28mm major diameter. It is believed that there are several Toyota clutches which will have this in their centre. The original GS450h flywheel and coupler also contains the appropriate slined centre, of course.
GS450h shift position sensor
  • It is recommended to purchase one which has the electric oil pump fitted - these are a costly item as the bearings in them often fail, in some cases they cost more than the transmission.
Control Board
An open-source VCU, designed by Damien Maguire, can be purchased as both partially populated and fully populated and tested boards on his website:
GS450h transmission and oil pump temperature sensor
Lexus GS450H VCM Fully Built and Tested
For those who have purchased the fully built board, the mating connectors for the VC are Molex parts:
GS450h transmission speed sensor
  • 33472-2002 (Left side, grey in colour)
  • 33472-2001 (Right side, black in colour)
  • 33012-2002 (Crimp terminals)
Development History
Vendors
- ?? List of known vendors with support?
Support
