Toyota Prius Gen3 Board
Prius Inverter
- Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
- 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
Development History
Vendors
Support
Inverter Model Numbers
| G9200-47180 | NO | Photo diyelectriccar.com | |||||
| G9200-47141 | Auris 2012, RHD | NO | |||||
| G9200-52032 | Yaris 2015 | F1759-52010 04 | F1789-52010 | YES | Long 143mm | NO | Forum Thread openinverter.com Forum Thread openinverter.com |
| G9200-47190 | Auris | F1759-52010 04 | ? | NO | Forum Thread openinverter.com | ||
| G9201-52011 | Yaris | YES | NO | Forum Thread openinverter.com | |||
Assembly Notes
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes. (Add details)
Source Documentation:
