Toyota P610 CVT
Revision as of 21:05, 17 July 2022 by Crasbe (talk | contribs) (Crasbe moved page Toyota/P610 CVT to Toyota P610 CVT: Remove "unnecessary" slash)
Description
The P610 is considered a fourth generation e-CVT. It is cooled via an external heat exchanger. The rotors differ from previous generations where they sit parallel instead of inline with one another.
Model Code
1NM
Applications
  • Toyota Prius (2016-2022)
  • Toyota Prius Prime (2016-2022)
Specifications
MG1
Rated Voltage: 600V
Max Output: 23 KW (31 HP)
Max Output Torque: 40 NM (30 lb-ft)
MAX RPM: 17000
Power split device planetary gearset ratio is 3.6:1.
MG2
Rated Voltage: 600V
Max Output Power: 53 KW (71 HP)
Max Output Torque: 163 NM (120 lb-ft)
Max RPM: 17000
Motor is sent through gear reduction of 3.118:1.
Final Drive Ratio
MG2 to final drive ratio: 10.838:1 (Prius), 12.3:1 (Prius Prime)
Ring to pinion gear ratio: 3.476:1 (Prius), 3.947:1 (Prius Prime)
Oil Pump
(Prius) Trochoid pump driven by engine shaft. It is a larger size compared to the P410 and P510. The pump is mounted internally.
(Prius Prime) External electric pump.
Fluid Capacity
??L of Toyota WS fluid.
Weight
179 lbs
MG1 & MG2 Stators
Temperature Sensor
MG1 & MG2 Resolvers
The connector also includes MG1 and MG2 temperature sensors
Park Shift Linkage Motor
Reference
Weber State University: 2016 - 2022 Prius, Prius Prime Transaxle - P610 Deep Dive
Wikipedia: Toyota Prius (XW50)
