Toyota P410 CVT
Description
The P410 is considered a third generation e-CVT.
Model Code
3JM
Applications
- Toyota Prius (2010-2015)
- Toyota Plug-in Hybrid (2012-2015)
- Toyota Prius V (2010-2017)
- Lexus CT 200h (2011-?)
Specifications
MG1
Rated Voltage: 650V
Max Output: ?
MAX RPM: 13500
Power split device planetary gearset ratio is 3.6:1.
MG2
Rated Voltage: 650V
Max Output Power: 60 KW (80 HP)
Max Output Torque: 207 NM (153 lb-ft)
Max RPM: 13500
Motor is sent through "motor speed reduction" gearset with a ratio of 2.636:1.
Final Drive Ratio
MG2 to final drive ratio: 8.615:1
Ring to pinion gear ratio: ??:1
Oil Pump
Fluid Capacity
??L of Toyota WS fluid.
Weight
202.8 lbs
MG1 Stator
MG2 Stator
MG1 Resolver
MG2 Resolver
Park Shift Linkage Motor
Reference
Weber State University: 2010 - 2015 Prius Transaxle - P410 Deep Dive
