Volkswagen Heater
Revision as of 05:54, 7 February 2022 by Arber333 (talk | contribs)
VW heater P/N are:
  • 3Q0963231A
  • 3Q0963231C
  • 3Q0963231E
LIN messages for the water heater:
ID 33 (0x61)
  • length 8 Byte / ENHANCED Checksum
  • Byte 0 =1 at HV voltage under 200V, =0 above 200V (below 200V it want work, so its a kinde of HV OK)
  • Byte 1 =112, always, i dont know why
  • Byte 2 =RPM as set via PID=32 in Byte 0
  • (Byte 3 =110 below 200V, =14 above 200V, =46 when er running)
  • Byte 3 bit 6= HV not OK
  • Byte 3 bit 5= running
  • Byte 5 =temperature 160 at 24°C, i don't know the scaling and what themperature that is til now
  • Byte 6 =54 at 109V, =28 at 56V =83 at166V scaling: Voltage/2
ID28 is sent for control, every 50ms
Byte 0 is power, last bit of byte 1 starts and stops
HV cable P/N is 3Q0971475 or 5Q0971475.
LV connector looks like it is Webasto 1J0973714 8P type.
HV connector HVA 280 KEY_E from TE
  • +HV near to the body,
  • -HV far from the body
LV Connector 1J0973714
  • Pin 1 is permanent 12V
  • Pin 2 is GND
  • Pin 4 is LIN
