The pedal module has two independently working sensors (potentiometer or hall effect) for redundancy and plausibility checks. Sensor 2 outputs exactly half the voltage of Sensor 1.
In the original design the DME (Digital Motor Electronics) provides an independent, precision +5V sources for each of the two sensors. It should be noted here that the +5V supply voltage should be precise and stable to assure no erroneous readings from the Inverter Controller.
The Accelerator Pedal Module for manual and automatic gearbox do not differ in their pinout or electrical connector used, so the kickdown switch is probably just a mechanical restrictor. This has to be verified!
BMW E46 Facelift Accelerator Pedal
BMW E46 Throttle Pedal SchematicBMW E46 Throttle Pedal ETK [1]
Pinout and Cable Colors
Pin Number
Cable Color
Function
1
Brown-Green
Ground
2
Brown
Ground
3
Yellow-Green
+5V Supply
4
White
Signal Sensor 1
5
Yellow
+5V Supply
6
White-Green
Signal Sensor 2
Voltage Range
Version
Part Number
Sensor 1 - 0%
Sensor 1 - 100%
Sensor 2 - 0%
Sensor 2 - 100%
Manual Gearbox
35 42 6786282
Automatic Gearbox
35 42 6786281
Part Numbers
No
Description
Part Number
Status
01
Accelerator Pedal Module, Automatic Gearbox
35 42 6786281
01
Accelerator Pedal Module, Manual Gearbox
35 42 6786282
02
Adapter Plate, Accelerator Pedal Module
35 42 6772703
02
35 42 6772704
03
Torx-bolt with washer, M8x20
07 12 9905423
04
Accelerator Pedal Bracket
35 41 1163875
Until 09/2003
04
Frame
32 30 3411677
From 2003/09
05
Self-locking hex nut, M6
07 14 7153450
From 07/2007
06
Blind plug, D=25mm
35 41 1163890
07
Socket Housing 6 Pin
61 13 8383300
Bushing contact 0.2-0.5mm²
61 13 0005197
BMW E60/E61 Throttle Pedal
BMW E60/E61 Throttle Pedal SchematicBMW E60/E61 Throttle Pedal ETK [2]
