External links
Forum discussion
> CAN logs
> I3 LIM CAN dbc1
BMW I3 HV components
LIM versions
LIM versions
SN IEC 61851
J1772 (AC)
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
Mini cooper SE
now
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1 / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545
Audi 7M0 973 119
TE 1-967616-1
X Replacement Pins 5-962885-1
X Rubber Seal 1-967067-1
LIM pinout
1B Pinout:
Pin # Function Description
1B-1 -
1B-2 -
1B-3 LED_M Lighting Charge Socket? (Not necessary)
1B-4 LOCK_MOT+ Charge Inlet Lock Motor
1B-5 LOCK_MOT- Charge Inlet Lock Motor
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 - Internally connected to GND
1B-16 LOCK_FB Charge Inlet Lock Feedback (1k unlocked, 11k locked)
2B Pinout:
2B-1 CP Pilot (Charge Inlet)
2B-2 PP Proxy (Charge Inlet)
2B-5 GND Ground (Charge Inlet)
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-5 U_HV_DC Charge Inlet DC Voltage (current input 3-20mA?)
4B-10 COV_MOT- Charge Inlet Cover Motor (Not necessary)
4B-11 COV_MOT+ Charge Inlet Cover Motor (Not necessary)
4B-12 COV_FB Charge Inlet Cover Feedback (connect to GND to simulate open cover)
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
CAN communication
0x12F Wake up VCU 100ms
0x1A1 Vehicle speed VCU 20ms
0x3E9 Main LIM control VCU 200ms
0x03C Vehicle status VCU 200ms
0x2A0 Central locking VCU 200ms
0x397 OBD VCU 200ms
0x3F9 Engine info VCU 200ms Rex?
0x3A0 Vehicle condition VCU 200ms
0x330 Range info VCU 200ms
0x432 BMS SoC VCU or BMS 200ms
0x51A Network management VCU 200ms
0x540 Network management 2 VCU 200ms
0x512 Network management edme VCU 200ms
0x560 Network management kombi VCU 200ms
0x510 Network management zgw VCU 200ms
0x328 Counter VCU 1s
0x3E8 OBD reset VCU 1s
0x2F1 Lim DC charge command 2. VCU 100ms
0x2FA Lim DC charge command 3. VCU 1s
0x2FC Charge flap control VCU 100ms
Messages sent by LIM
0x29E CCS charger specs LIM
0x2EF Min available voltage from the ccs charger. LIM
0x2B2 Current and Votage as measured by the ccs charger LIM
0x3B4 EVSE info CP, PP & inlet voltage LIM
0x337 Inlet lock status LIM
LIM peripherals
isolated DC Voltage sense board by muehlpower
Large fast charge contactor control
This makes it a bit harder to use different contactors.
The easiest option is to place a 15 ohms resistor (with heat sink) in parallel to simulate the original contactor coil and a small relais to drive the large Gigavac contactor with internal PWM economizer or dual coil.
Each of the two 15 ohm resistor has to dissipate ~6W @ 13.4V, 50% PWM.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Inlet lock feedback
DUOSIDA / MIDA CCS inlet
The i3 uses a quite expensive Phoenix CCS inlet and it would be nice to be able to use the cheaper Duosida CCS inlets.
The charge inlet lock should work with the Duosida lock as well but the feedback (1k unlocked, 11k locked) is a bit different which requires some additional resistors.
CCS inlet lock
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
RGB LED
Charge control
The EVSE (charging station) shares it’s limits with PWM during IEC 61851/ J1772 AC charging or PLC during DIN 70121 or ISO 15118 CCS sessions but often the car can not handle the max available power of the charging station.
The actual battery voltage and battery current is needed by the LIM to check the respond of the charging station. In this setup the battery voltage and current gets measured by a Isabellenhütte IVT CAN bus sensor but those values could also be measured and shard on the CAN bus by the BMS. (CAN message 0x112)
Battery dependant charging current control
During (fast) charging a cell voltage and cell temperature dependant current limit is very important.
CCS inlet temperature sensors
Many CCS inlets have DC contact temperature sensors to avoid overheating if the contact resistance is high for some reason. The LIM has no temperature sensor inputs but the VCU could be connected to the sensors (usually PT1000 or NTC) and reduce charging speed if the inlet gets too hot.
On board charger control
The LIM shares measured PP (charging cable) and CP (charging station) AC current limits in the CAN message 0x3B4 EVSE info.
If the on board charger accepts a AC current limit this value can be directly used but some chargers can only be controlled with DC current commands.
Since we don't know the actual AC current we can only estimate it with a fixed AC voltage and charger efficiency.
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
LIM logs
Observations
LIM board components
components
