As these can be found affordably on eBay and from auto wreckers, they have been pursued as an open-source charger project.
CAN logs and other data
https://github.com/damienmaguire/BMW-i3-CCS
LIM versions
SN | IEC 61851
J1772 (AC) |
61 35 9 380 352 | x | x | ? | BMW i3 | Nov 2015 | x | |
Mini cooper SE |
now |
The LIM's are available new from BMW spare parts suppliers for € 240 but there is probably some programming necessary. ???
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
X | Replacement Pins | 5-962885-1 |
X | Rubber Seal | 1-967067-1 |
1B-1 | - | |
1B-2 | - | |
1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
1B-4 | LOCK_MOT+ | Charge Inlet Lock Motor |
1B-5 | LOCK_MOT- | Charge Inlet Lock Motor |
1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
1B-10 | GND | Ground |
1B-11 | - | |
1B-12 | - | |
1B-13 | - | |
1B-14 | - | Internally connected to GND |
1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enabled signal for the in car charger? or drive interlock signal? |
1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked?) |
2B-1 | CP | Pilot (Charge Inlet) |
2B-2 | PP | Proxy (Charge Inlet) |
2B-3 | Jumper | Connected to Pin 4 |
2B-4 | Jumper | Connected to Pin 3 |
2B-5 | GND | Ground (Charge Inlet) |
2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
4B-1 | HV+_SZ+ | Contactor Control |
4B-2 | HV-_SZ+ | Contactor Control |
4B-3 | HV+_SZ- | Contactor Control |
4B-4 | HV-_SZ- | Contactor Control |
4B-5 | U_HV_DC | Charge Inlet DC Voltage (current input 4-20mA?) |
4B-6 | LED_RT | Charge Status Light |
4B-7 | LED_GN | Charge Status Light |
4B-8 | LED_BL | Charge Status Light |
4B-9 | LED_GND | Charge Status Light Ground |
4B-10 | COV_MOT- | Charge Inlet Cover Motor (Not necessary) |
4B-11 | COV_MOT+ | Charge Inlet Cover Motor (Not necessary) |
4B-12 | COV_FB | Charge Inlet Cover Feedback (GND if open) |
Wiring Diagram
Observations
