Revision as of 10:27, 16 June 2021 by Bitterandreal (talk | contribs) (added LIM versions table, updated pinout table...)
As these can be found affordably on eBay and from auto wreckers, they have been pursued as an open-source charger project.
CAN logs and other data
https://github.com/damienmaguire/BMW-i3-CCS
I3 hv components
Forum discussion
LIM versions
Only AC_DCO versions work for CCS. (Check if you have a MAC adres on the sticker!)
The following SN are confirmed to work.
LIM versions
SN J1772 (AC) DIN 70121 ISO 15118 ISO 15118-20 Car Dates Works
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
61 35 9 380 352 x x BMW i3 Nov 2015 x
61 35 6 805 847 x x BMW i3 Jul 2016
61 35 9 454 319 x x BMW i3
Mini F56
The LIM's are available new from BMW spare parts suppliers for € 240 but there is probably some programming necessary. ???
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1 / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545
Audi 7M0 973 119
TE 1-967616-1
X Replacement Pins 5-962885-1
X Rubber Seal 1-967067-1
1B Pinout:
Pin # Function Description
1B-1 LED_S Lighting Charge Socket?
1B-2 Charge Door Lock Motor????
1B-3 LED_M Lighting Charge Socket?
1B-4 LOCK+ Charge Inlet Lock Motor
1B-5 LOCK- Charge Inlet Lock Motor
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 -
1B-15 CHARGE_E Goes to KLE. Guessing this is charge enabled signal for the in car charger? or drive interlock signal?
1B-16 LOCK_FB Charge Inlet Lock Feedback (1k unlocked, 11k locked?)
2B Pinout:
2B-1 CP Pilot (Charge Inlet)
2B-2 PP Proxy (Charge Inlet)
2B-3 Connected to Pin 4 (Diag?)
2B-4 Connected to Pin 3
2B-5 GND Ground (Charge Inlet)
2B-6 US charging inlet AC/DC???
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-1 HV+_SZ+ Contactor Control
4B-2 HV-_SZ+ Contactor Control
4B-3 HV+_SZ- Contactor Control
4B-4 HV-_SZ- Contactor Control
4B-5 U_HV_DC Charge Inlet DC Voltage (current input 4-20mA?)
4B-6 LED_RT Charge Status Light
4B-7 LED_GN Charge Status Light
4B-8 LED_BL Charge Status Light
4B-9 BR_GND Charge Status Light Ground
4B-10 ZV_LS- Charge Inlet Cover Motor
4B-11 ZV_LS+ Charge Inlet Cover Motor
4B-12 SENS_LS Charge Inlet Cover Feedback (GND if open)
Observations
Functional LEMs have come from vehicles where the Air Bags have deployed, indicating that the module still works after a "Safety" event has occured
