Revision as of 18:48, 9 June 2021 by Bji900 (talk | contribs) (Added Observation Section, and some notes)
As these can be found affordably on eBay and from auto wreckers, they have been pursued as an open-source charger project.
CAN logs and other data
https://github.com/damienmaguire/BMW-i3-CCS
I3 hv components
Forum discussion
Power Limits
The limits for pre 2017/26 are 0V-500V 0A-250A, post 2017/27 0V-1000V -500A-+500A.
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1 / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545
Audi 7M0 973 119
TE 1-967616-1
X Replacement Pins 5-962885-1
X Rubber Seal 1-967067-1
1B Pinout:
Pin # Function Description
1B-1 LED_S Lighting Charge Socket
1B-2 ZV_LKL+ Charge Door Lock Motor
1B-3 LED_M Lighting Charge Socket
1B-4 ZV_LADE+ Hood Lock
1B-5 ZV_LADE- Hood Lock
1B-6 CAN
1B-7 CAN
1B-8 Wake up signal
1B-9 Power
1B-10 Ground
1B-11
1B-12
1B-13 SENS_LKL Charge Door Lock Sensor
1B-14 ZV_LKL- Charge Door Lock Sensor
1B-15 CHARGE_E Goes to KLE. Guessing this is charge enabled signal for the in car charger?
1B-16 ZV_LADE Hood Lock
2B Pinout:
2B-1 Pilot
2B-2 Proxy
2B-3 Diag? Looped back to Pin 4?
2B-4
2B-5 GND Ground. (Charge Socket)
2B-6
3B Pinout:
- N/A
4B Pinout:
4B-1 HV+_SZ+ Contactor Control
4B-2 HV-_SZ+ Contactor Control
4B-3 HV+_SZ- Contactor Control
4B-4 HV-_SZ- Contactor Control
4B-5 U_HV_DC
4B-6 LED_RT Charge Status Light
4B-7 LED_GN Charge Status Light
4B-8 LED_BL Charge Status Light
4B-9 BR_GND Charge Status Light
4B-10 ZV_LS- Charge Socket Locking
4B-11 ZV_LS+ Charge Socket Locking
4B-12 SENS_LS Charge Socket Locking
Observations
Functional LEMs have come from vehicles where the Air Bags have deployed, indicating that the module still works after a "Safety" event has occured
