Tesla Model S/X Large Drive Unit ("LDU")
The Tesla Model S/X Large Rear Drive Unit...
Ampseal Connector Mapping
PIN NUMBER | OEM | OPEN SOURCE |
1 | IGN +12V | IGN +12V |
2 | BRAKE ON N.O. | BRAKE ON |
3 | BRAKE OFF N.C. | PRECHARGE RELAY |
4 | CAN HIGH | CAN HIGH |
5 | CAN LOW | CAN LOW |
6 | CHG PROXIMITY | MAIN CONTACTOR |
7 | HVIL IN | FORWARD |
8 | HVIL OUT | REVERSE |
9 | ENC +5V | ENC +5V |
10 | ENC A | ENC A |
11 | GND | GND |
12 | ACCEL 1 +5V | ACCEL 5V |
13 | ACCEL 1 | ACCEL INPUT |
14 | ACCEL 2 | BRAKE TRANSDUCER |
15 | ACCEL 1 GND | ACCEL GND |
16 | ENC B | ENC B |
17 | ENC GND | ENC GND |
18 | ENC SHIELD | ENC SHIELD |
19 | CAN HIGH OUT | |
20 | CAN LOW OUT | |
21 | ACCEL 2 +5V | CRUISE IN |
22 | ACCEL 2 GND | GND |
23 | 12V ALWAYS T30 | START |
Tesla large drive unit logic board
Application Info
You may also set parameter „udcsw“ and „udcmin“ to 0 and start drive mode by pulsing 12V on „Start“. Then connect a pot between 5V, GND and „Pot“ (wiper). This will also spin the motor AND enforce a speed limit.
