VW Touran Conversion
Revision as of 13:01, 15 May 2019 by Johu (talk | contribs) (Faults)
I will start loosely collecting infos on the VW Touran from 2004.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I will have to look into reading the pedal directly. Here is its pin map:
Throttle pedal pin map
Pin # Color code Function
1 green/white 5V
2 yellow/green 5V
3 brown/blue GND
4 white/blue Throttle 1 0.75V-4.1V
5 green/blue GND
6 blue/black Throttle 2 0.38-2.05V
ECU connector
Touran ECU with Rev 2 main board
11 - Throttle GND (Pin 5)
12 Throttle 2 out (Pin 6)
13 Throttle 5V (Pin 1)
33 Throttle GND (Pin 3)
34 Throttle 1 out (Pin 4)
35 Throttle 5V (Pin 2)
31 Vacuum sensor GND
37 Vacuum sensor 5V
83 Vaccum sensor signal
86 Ignition On?
87 While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU
67 CANL
68 CANH
Power steering
CAN bus
Some Touran CAN messages
COB Id Len Function Notes
0x380 Byte 2: 0-0xFE throttle position Produced by ECU, so n/a when removed
0x1A0 1 Byte 1, Bit 3: Brake pedal switch Produced by whoever
0x280 Bytes 2 and 3: RPM*4 Produced by you, Controls the rpm gauge
0x480 8 Byte 6, Bit 2: Cruise light, Byte 1, Bit 3: EPC, Bit 4: engine Controls various indicator lights
0x288 Byte 1: Temp Gauge 0.75x temp - 48 Produced by you, Controls temp gauge
0x38A Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+
0x572 Byte 0, Bit 3: Key switch in start position
Faults
On this connector we find switched 12V, GND and the oil pressure signal (top right)
After powering up the engine I got two error messages: STOP low coolant and something about an oil sensor. The first can be solved by filling the reservoir with water. The second is probably down to the missing oil level sensor. I will investigate.
Update on oil level warning: I fitted a 1k2 Ohm resistor from pin 2 to pin 3 (generates 2.5V "oil level") and the warning is gone.
Update 2: no it's not gone, it's a bit more complex. Read https://wak-tt.com/guides/ttc.pdf page 84.
