Tesla Model S/X GEN2 Charger
Revision as of 02:37, 15 November 2020 by Bratitude (talk | contribs) (programing v5 board)
The Tesla GEN2 is a single/three phase 10kW AC charger that was fitted in the Model S from 2012 until it was replaced in the 2016 'facelift' model with GEN3.
One or two GEN2 chargers are installed beneath the rear seats.
Replacement control boards
replacement control board https://github.com/damienmaguire/Tesla-Charger
programing
you'll need a st-link v2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
st-link programming utility: https://www.st.com/en/development-tools/stsw-link004.html
stm32_loader.hex https://openinverter.org/forum/viewtopic.php?f=7&t=1119
Charger_gen2_v5.hex https://github.com/damienmaguire/Tesla-Charger/tree/master/V5/Software/Binary
This will ask to open a file, you choose: "stm32_loader.hex" from OpenInverter.org, download ahead of time. This will change what shows up in the viewing window.
Future updates can be done via wifi.
