CAN bus with Arduino Due
You will need the following:
- An Arduino Due board
- One or two SN65HVD230-based CAN transceivers
- An SPI Micro SD storage module (optional)
Here are the steps:
Configure your Arduino IDE
Download and install the Arduino IDE on your computer
Tools -> Board -> Boards Manager. Type "due" in the search box and install "Arduino SAM Boards (32-bits ARM Cortex-M3)"
Connect your computer to the the "native" USB port on the Arduino Due board with a USB cable. The Due has two USB ports and they're used for different purposes.
Make sure your Arduino board is selected with Tools -> Board: "Arduino Due (Native USB port)"
File -> Examples -> 01.Basics -> Blink
Sketch -> Upload
Push the reset button on your Due. You should now see a blinking light. Congratulations! You've successfully compiled and loaded your first program and your IDE is working.
Get CAN working
Tools -> Manage Libraries... Type "due_can" in the search box and install "due_can"
File -> Examples -> due_can -> CAN_ExtendedPingPong
Sketch -> Upload
Tools -> Serial Monitor
Install GV-RET
You need to install a number of libraries (in addition to the due_can library installed in the last section).
Tools -> Manage Libraries... and install the following libraries:
- SdFat
- DueFlashStorage
Now install the following libraries manually. In each case, the installation procedure is:
- Download the .zip file
- Rename the file to remove "-master" or any other postfixes. This is important!
- Install the library with Sketch -> Include Library -> Add .ZIP Library... and select the file.
You need all of these:
Once the libraries are all installed, you can install GV-RET. Go to the GitHub webpage, and click on Code -> Download .ZIP.
Expand the .zip file and put the folder in your Arduino sketchbook location. Open the GV-RET project and install it
File -> Open -> GVRET.ino
Sketch -> Upload
Resetting to factory defaults
Using stored values for digital toggling system
Running on CANDue hardware
Build number: 343
Done with init
Get started with SavvyCAN
SavvyCAN is a powerful, free, open source tool for analysing CAN traffic. Download and install it on your computer. It can be a bit intimidating, so there's a 30 minute tutorial to help you find your feet:
<youtube>kdA5Gdf3FAk</youtube>
No doubt you're far to impatient to sit through a tutorial, so let's dive straight in and connect to your Due. Go back to the Arduino IDE and note down the name of your Due USB connection. On my Mac, it's "/dev/cu.usbmodem2441"
Create New Connection
After a few seconds, you should see "Connected" in the Status field. If it doesn't connect, try pushing the reset button on your Due or click Reset Selected Device in SavvyCAN.
