Coolant Fittings
Revision as of 16:29, 20 December 2024 by Tom91 (talk | contribs) (Categories)
This is a list of coolant fittings that may be useful in an EV swap.
Part Number Fitting Type Number of ports Original Use With Bleeder? Fitting 1 Size Fitting 2 Size Fitting 3 Size Other part numbers
3B0122291B Quick Connect 2 Radiator Hose No NW16
1K0122291C Quick Connect 3 Heater Hose Hose
17127515502 Barb Coupling 2 Radiator Hose Screw FEB-170759, URO-014663
Many more can be found online at the following links,
https://www.fcpeuro.com/Parts/?keywords=Coolant%20Connector
https://www.fcpeuro.com/Parts/?keywords=Coolant%20Fitting
https://www.iq-parts-shop.com/en/search/norma+quick+nw/
Quick Connect Coolant Fittings Info
Norma Quick Fitting
https://www.norma-connects.com/sites/dsemea/files/qbank/documents/NORMA-Quick-Connectors-Catalogue.pdf
Link to the CAD models page
CAD Models
