VAG MLBevo MQB Chargers
Revision as of 15:40, 5 September 2025 by Heye (talk | contribs) (Added scrap yard note (The plug is very, very common and far cheaper to get from a scrapyard))
There's a generational difference between the 1-2 phase PHEV chargers, and the newer MLBevo type used on the Audi E-Tron, E-Tron GT & Porsche Taycan
Difference between MLBevo/MQB vs. MEB Chargers
MEB has different AC connector and therefore also different chargeport. Possibly not compatible with all the information here. The E-Tron chargers have several things which make them a bit different, one major being the LIN LED module and Door actuator, as well as only having a Hybrid CAN connection (No Drive CAN).
MLBevo/MQB Chargers Overview
There are many different variants of MQB and MLBevo chargers with a wide range of potential power outputs.
These charges are not recommended if you are looking for a known working solution.
Part Number Version Power Rating Phase Vehicle Usage Coolant Connections Dimensions Comments Reverse Engineered AC-Plug Connector Communication Plug Connector Coolant hose connector
5QE915685 3.6kW Single
5QE915685C OBCTYPP036G26V01 3.6kW Single SEAT/CUPRA Leon/Formentor Hybrid Bottom
5QE915682 3.6kW Single
5QE915682AA
5QE915682AF
04S, 13S 3.6kW Single VW Golf MK7 GTE
Audi A3 8V 2018-2020
Bottom Case not welded, 2 HV pass throughs
5QE915682AG 07S 3.6kW Single Audi A3 8V e-tron Bottom
5QE915682AK 03S 3.6kW Single VW Golf MK7 GTE Bottom Yes
5QE915682M OBC C0 3.6kW Single VW Passat Hybrid Bottom
5QE915681AT OBC 7200W 7.2kW Single Audi Q7 e-tron 4M GTE Bottom Case not welded
5QE915681BP OBCTypP072G30V02 7.2kW Dual VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba Left side Made by Delta, HV pass through
5QE915681BQ OBCTypP072G30V03 7.2kW Dual Porsche Cayenne Hybrid 2017-2021 Left side
5QE915681CQ OBCTypP072G30V03 7.2kW Dual Audi A8 PHEV 2022 Left side No HV pass through.
5QE915681B OBC 7200W 7.2kW Dual VW e-Golf 2017-2022 Bottom Case not welded
5QE915681D OBC 7200W 7.2kW Dual Audi Q5 PHEV 2020-2021 Right side Case not welded, no HV pass through
5QE915681N OBC 7200W 7.2kW Dual VW e-Crafter Bottom Case not welded
5QE915684A 11kW Three Audi e-tron Opposite End of Electrical
5QE915684AD
5QE915684AT
5QE915684J
OBCTYPP110G10V01 11kW Three Audi e-tron
Audi e-tron Sportback 2019-2021
Opposite End of Electrical 300 x 200 x 100 mm Made by KOSTAL
Taredown can be purchased here
5QE915684AL
5QE915684BG
5QE915684BK
5QE915684CB
5QE915684CR
OBCTYPP110G10V03 11kW Three Porsche Taycan
Audi e-tron GT
Right Side Made by KOSTAL
Dual AC inputs
Probably easiest to buy an original CCS port with Loom 60 pin plug Part Number: 5Q0906379
Supersession(s): 3C0906379; 5Q0-906-379
Normaquick NW12
  • Associated Part Numbers: 3B0122291B, V10 9858, V10-9858, V10-9858-INT, V10.9858, V109858
(unverified)
5QE915684BJ OBCTYPP110G10V04 11kW Three Audi e-tron(?) Right Side Made by KOSTAL
Normaquick NW12
(unverified)
5QE915684BC
5QE915684CM
OBCTYPP110G10V05 11kW Three Audi e-tron Opposite End of Electrical Made by KOSTAL
Normaquick NW12
(unverified)
9J1915681AD
9J1915681AH
OBC 22kW C3 ROW 22kW Three Porsche Taycan 2019 Right Side 498 x 235 x 100 mm Longer case than other models.
Made by Meta System in Italy
Taredown available here
Normaquick NW12
(unverified)
1EA915684AD
1EA915684AF
1EA915684BF
1EA915684BG
OBCTYPP110G040V04K 11kW Three Audi Q4 e-tron 2021
Skoda Enyaq 2020
VW ID.3 2020
VW ID.4 2021
AC input end 480 x 313 x 102 mm Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic. Those are linkly not comptaible with all the information in the wiki.
Made by KOSTAL
Not the same as MLBevo
LV Connection
VW part number 5Q0906379. The 60 pin signal connector is TE part number 2208272-1 .Pins are two sizes of TE pins 5-968221-1 and 1241608-6. Can be found also on Aliexpress as 60 Pin ECU connector or on scrapyards on the ECU of most newer fossil fuel powered VAG cars.
Pinouts of 60 Pin Connector
VW Golf PHEV Seat Mii / VW e-Golf[1] MLBevo (Audi Etron)[2]
Pin Function Comment Function Comment Function Comment
1 Terminal 30 (permanent 12V) Terminal 30 Terminal 30 confirmed
2 Charging Cover Lock (+) - Socket A
3 Switch/LED Common - Socket A confirmed / Sensor Ground / Both pin 3 and 45 can be tied together
4 Charge Port RGB LED +12v o/p LED - Red - Socket A
5 Charge Port RGB LED +12v o/p LED - Green - Socket A
6 LED - Blue - Socket A
7 Illumination LED - Socket A
8
9 Powertrain CAN bus, high Powertrain CAN bus, high CAN H - Bus #1 confirmed
10 Powertrain CAN bus, low Powertrain CAN bus, low CAN L - Bus #1 confirmed
11 Hybrid CAN bus, high Hybrid CAN bus, high CAN H - Bus #2
12 Hybrid CAN bus, low Hybrid CAN bus, low CAN L - Bus #2
13 HVIL IN HVIL IN Pilot Line In
14 LIN Comms
15 HVIL OUT HVIL OUT Pilot Line Out
16 Lock drive +. Drive to 12v to close lock. The lock can be coded off with ODIS Plug Lock (+) - Socket A
17 Lock Drive – Drive to 12v to open lock Plug Lock (-) - Socket A
18 Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel Plug Lock Position - Socket A
19 Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel Plug Lock Ground - Socket A
20
21 Immediate charge buttons Function LED #1
22 Charge Port RGB LED +12v o/p
23 Control Pilot (CP) CP - Socket A
24 Plug Present (PP) (4.7K to ground in socket) PP/CS - Socket A
25 Immediate charge buttons Charge Button - Socket A
26 Search Light (Shared - Possible LED4 in config)
27 Temperature sender for charging socket. 1067R at approx 15C AC Charge Port Temperature Sensor (-) - Socket A
28 Temperature sender for charging socket. 1067R at approx 15C AC Charge Port Temperature Sensor (+) - Socket A
29 Charging Cover Position Switch - Socket A
30 AC Charge Port Temperature Sensor (+) - Socket B confirmed
31 Charge port door lock actuator The flap can be coded off with ODIS Charging Cover Lock (+) - Socket B
32 Charge port door lock actuator Charging Cover Lock (-) - Socket B
33 Charge port door lock actuator Charging Cover Position Switch - Socket B confirmed / Other side tied to sensor ground pins 3/45
34 Charge port door lock actuator
35 Switch/LED Common - Socket B confirmed
36 LED - Red - Socket B confirmed
37 LED - Green - Socket B confirmed
38 LED - Blue - Socket B confirmed
39 Illumination LED - Socket B confirmed / Other side tied to ground pin* (Debating if this should be tied to the 3/45 pins)
40 CP - Socket B confirmed
41 PP/CS - Socket B confirmed
42
43
44
45 Switch/LED Common - Socket B confirmed / Both pin 3 and 45 can be tied together
46 Plug Lock (+) - Socket B confirmed
47 Plug Lock (-) - Socket B confirmed
48 Plug Lock Position - Socket B confirmed / Resistive 1k/11k unlocked/locked) *Other side tied to sensor ground pins 3/45*
49 DC Charge Port Temperature Sensor (+) - Socket B confirmed
50 Charging Cover Lock (-) - Socket A
51 Immediate charge buttons Charge Button - Socket B confirmed / Other side tied to sensor ground pins 3/45
52 DC Charge Port Temperature Sensor (-) - Socket B confirmed
53 Chademo CAN-H
54 Chademo CAN-L
55 Chademo
56 Chademo
57
58
59
60 Terminal 31 (Ground) Terminal 31 confirmed
AC Connection
Golf GTE and all 5QE915682 series 3.6 kW chargers - Part number TE Connectivity 2103177-2
MLBevo
TE YHVA630-5phm-6mm-A and HV output coding A is 2141256-1
HV Connection
It doesnt care what you connect to the HV wires. 360v, 12v, heating element, dead short. Its mission in life is pumping current. It just dumps out voltage even when it does not see any voltage present.
Coding
LIN Devices still show up within the DTC Memory, However no functional issues with them disconnected as long as the coding has them coded out. Similar errors exist for the door and other coded out options. Assumption is that the base software still has the DTC codes enabled for faults, however the selection is universal for the base charger option. (much like how most times you can code out a O2 sensor, but the DTC code will remain unless digging deeper into the ECU programming)
VCDS
Bitfield 0 Bitfield 1 Bitfield 2 Bitfield 3
CP standard - SAE/
vehicle category - Electric Vehicle / Hybrid
20kW charger
AC charging socket B
AC charging socket A
PLC charging socket B
PLC charging socket A
DC Charging - Chademo
Country encoding (NAR/
HV activation auxiliary contactor
Charging socket resistor B
Charging socket resistor A
AWC installed - Wireless charging
Number of AC chargers (One/Two)
Mobile Online Services (MOD)
Sub-Grid operation
Charging cover lock (charging socket B)
Charging cover lock (charging socket A)
HV activation DC charging read back
Maximum charging current (63A)
Charging cover lock detection (charging socket B)
Charging cover lock detection (charging socket A)
Plug lock DC charging socket
iWWT - Integrated water heat exchanger?
Type of connector lock detection - Limit Switch
Plug lock (charging socket A)
Brand/Marque (VW/Audi/Porsche)
Bitfield 4 Bitfield 5 Bitfield 6 Bitfield 7
Plug and Charge (PnC)
Power Line Communication
Settings Clear error memory
HV charge booster (400v->800v)
Charging button module
Second charging button
Local HV interlock
stimulus line installed
Variant coding 11 kW (reserve)
Parking Heater
Kessy
Diagnostic resistor loading button
LED 4 (DC/Combo)
LEDs DC/Combo
LED 4 (AC)
DC China socket installed
Installed DC combo box
Intelligent charging socket installed (LIN socket)
Installation status of DC charging socket B
Installation status of DC charging socket A
Two charger can B
Charging button module socket B
Diagnosis resistance charging button socket B
Installation location DC charging socket
ODIS
ODIS Engineering is a common tool that works with some of the simpler dongles e.g. a VAS6154 cable
PIWIS
CAN-Messages
MLBevo TX Messages:
The CAN signals for MLBevo appear to be totally different than those for the rest of the charger line.
Required:
  • BMS_01 - 0x191
  • BMS_02 - 0x1A1
  • BMS_03 - 0x39D
  • BMS_04 - 0x5A2
  • BMS_06 - 0x59E
  • BMS_07 - 0x5CA
  • BMS_09 - 0x96A955EB
  • BMS_10 - 0x509
  • BMS_11 - 0x96A954A6
  • BMS_16 - 0x9A555539 - Just contains IDs for cells with low/high charge or temps
  • BMS_27 - 0x9A555552
  • BMS_DC_01 - 0x578 - Contains the HV DC Voltage for CCS
  • ESP_15 - 0x1A2 - Holding Management System info
  • Klemmen_Status_01 - 0x3C0 - Key status Run/Start, etc...
  • DCDC_01 - 0x2AE - 12V DC converter - Just values related to electrical load
  • HVK_01 - 0x503 - Items related to HV Contactor & JB
  • HVEM_02 - 0x5AC - Useable Energy for Comfort Functions
  • HVEM_05 - 0x552 - Fun items relating to Max Voltage and Plug Release
Signals I'm sending In addition:
  • Airbag_01 - 0x40 - Monitors HV Deactivate status
  • BCM1_04 - 0x64F - BCM Charge Status indication - Likely just confirmation feedback
  • DCDC_03 - 0x5CD - 400v to 800v converter - Likely not required
  • EM1_HYB_11 - 0x37C - Signal for E-Motor Status - Can be 0 for standby
  • FCU_02 - 0x17B - Contains Tank Flap Release & Signal which may go High to signal ready for charging (EPB, Drive System Disabled)
  • NavData_02 - 0x485- This along with Authentic_Time_01 contain a 32-bit epoch unix time, used for the charge time calculation.
  • VIN_01 - 0x6B4 - Mux'd VIN# - Likely not required or just mimic the Donor Vin?
  • ZV_01 - 0x184 - Signal to unlock via ZT - Maybe will unlock charge plug
  • ZV_02 - 0x583 - Lock status, likely not required
Signals I haven't added:
  • Dimmung_01 - 0x5F0
  • Einheiten_01 - 0x643
  • ESP_49 - 0x96A954AE - Contains Value for Regen reserve, Guessing that ESP will average typical SOC% to reserve to allow regen - Likely not required
  • NVEM_02 - 0x663 - Contains Battery Voltage from Battery Data Module
  • MSG_HYB_30 - 0x153 - Only seems to use the Counter & Checksum?
Narrowed down to:
10ms:
0x191
100ms:
0x3C0
0x503
0x1A1
MQB TX Messages:
Golf Phev charger from a CAN perspective are a total of 7 messages. One on PT CAN : 0x187 and 6 on Hybrid CAN : 0x097 , 0x124 , 0x3a6 , 0x3af , 0x6a3 and 0x6a4.
Reference Implementations:
Charger Code References Status Comment
Audi E-Tron Charger (11kW) [3] Proved working Mitchy
7.2kW Cayenne Phev charger 5QE 915 681 BQ Arduino[4], ZombieVCU[5] [6] Proved working LRBen
2021 Seat Mii part number : 5QE915681BP
Golf PHEV part number : 5QE915682AK
Arduino Proved Working Damien
