DNR Reverse Forward Switch Parking Gear Shift
A complete directional switch with indication available on Aliexpress. There is a schematic/connection table is in last pic of my previous post :)
Drive outputs pin 2 & 7 Reverse outputs pin 3 & 6 pins 3 & 7 output +12v Pins 2 & 6 output whatever you feed to pin 1.
LEDs are not controllable separately, they switch color depending on selector position. This looks to me like it is a mechanical rocker switch with rocker covered with a knob, so nothing fancy in that sense :) There are two possible outputs for both D & R. One is positive (connected to the +12v supply, which also powers the leds) and the other output is dependent on the pin 1 connection. If pin 1 is not connected, you don't get an output from the pins defined as signal outputs.
