Coolant Fittings
This is a list of coolant fittings that may be useful in an EV swap.
Part Number | Fitting Type | Number of ports | Original Use | Fitting 1 Size | Fitting 2 Size | Fitting 3 Size | Image |
3B0122291B | Quick Connect | 2 | Radiator Hose | NW16 | |||
1K0122291C | Quick Connect | 3 | Heater Hose | ||||
Many more can be found online at the following links,
https://www.fcpeuro.com/Parts/?keywords=Coolant%20Connector
https://www.fcpeuro.com/Parts/?keywords=Coolant%20Fitting
https://www.iq-parts-shop.com/en/search/norma+quick+nw/
Quick Connect Coolant Fittings Info
