Volvo Power Steering Pump
Part Numbers and Versions
| Part Number | Vehicle Used in | Comment | |
| 30636927 | |||
| 31202520 | |||
| 36000075 | |||
| 36000116 | |||
| 36000772 | |||
| 36000801 | |||
| 36001211 | |||
| 36001485 | |||
| 36002698 | |||
| 36050678 | |||
| 8603041 | |||
| 8603274 |
Electrical Connection
The harness for the motor supply can be bought completely (Part Number: 30775461 [2]) or just the connector.
| Pin Number | Cable Color | Function | Comment |
| 1 | Red | Permanent +12V for Motor | Fused with 80A fuse (F2) |
| 2 | Black | GND | |
| 1 | Grey-Blue | Ignition +12V for Control | Fused with 10A fuse (F53) |
| 2 | CAN-?? | ||
| 3 | CAN-?? |
CAN Bus Control
The CAN bus protocol has been reverse engineered in the rus EFI forum[6] and a LUA script example exists[7]
Mechanical Dimensions
- fittings and sizes
- ↑ https://rusefi.com/forum/viewtopic.php?p=45946#p45946
- ↑ https://usparts.volvocars.com/p/Volvo_2007_C30-24l-5-cylinder/Wiring-Harness-Cable-Harness-Power-Steering-Pump-Electrohydraulic-Power-Steering-Service-Solution-Servo-Pump/42906949/30775461.html (Backup: )
- ↑ 3.0 3.1 Volvo C30 2007 Schematic, TP39103202
- ↑ https://usparts.volvocars.com/p/Volvo_2007_C30-24l-5-cylinder/Receptacle-Housing-Cable-Harness-Engine-Component-Parts-Electrical-Power-Steering-Module-EPS/42815694/31266849.html
- ↑ https://usparts.volvocars.com/p/Volvo_2007_C30-24l-5-cylinder/Receptacle-Housing-Electric-Power-Steering-EPAS-Electrical-Power-Steering-Module-PSCM/65250641/31346135.html
- ↑ https://www.rusefi.com/forum/viewtopic.php?f=4&t=2329
- ↑ https://github.com/rusefi/rusefi/blob/master/firmware/controllers/lua/examples/Volvo-electric-power-steering-pump.txt
