Volkswagen Heater
Revision as of 05:03, 4 January 2024 by Jason arnold (talk | contribs) (General Information: added in more info from datasheet (including connector part numbers), added annotated pinout photo)
General Information [1]
  • Operating Voltage: 280VDC - 450VDC
  • Power: 5kW (7kW "boost" between 350-450V)
  • Control via LIN by integrated electronics
  • Temperature control by integrated sensor
Pinout/Connectors
HV connector: TE 4-2103177-5 (HVA 280 series - key "E")
  • HV+ near to the body,
  • HV- far from the body
LV connector: TE 1-1394416-1
  • Pin 1 is permanent 12V
  • Pin 2 is GND
  • Pin 4 is LIN
LIN Bus Communication
Control and Answer Messages from/to Heater[2]
ID Description Length Checksum Type Byte 0 Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7
Dec: 28
Hex: 0x1C
PID: 0x9C
Control, every 50ms 2 ?? Power
0-2530W
scale: x10
Last bit: Start/Stop
Dec: 48
Hex: 0x30
PID: 0xF0
Feedback 8 ?? Power:
13 = 770W
26 = 1540W
?? ?? ?? ?? ?? Temperature in Temperature out
VW Part Numbers
Heater:
  • 3Q0 963 231 A
  • 3Q0 963 231 C
  • 3Q0 963 231 E
Cable assemblies:
  • HV cable is 3Q0 971 475 or 5Q0 971 475
  • LV cable appears to be 1J0 973 714
