In addition to the BMW 5 Series (G30) 530e the same battery pack can be found in the 7 Series (G12) 740e as well as the X Series(F15) X5. These battery packs consist of six battery modules yielding 351 volts. The same battery modules can be found in the 3 Series (F30) 330e but in a smaller form factor made up of only five modules and 293 volts.
The Electrical Energy Storage System in the 530e as well as the 740e has a code name of SP06 and a capacity of 26 Ah.
Second Gen (2019-present)
The newer SP41 high-voltage battery was installed in the G30 as well as the G12 Plug-in Hybrid Electric Vehicles starting in July of 2019. It has the same basic design as the SP06. The most significant change is the cell capacity increase from 26 Ah to 34 Ah.
Technical Specifications
Technical data
5 Series G30 PHEV (SP06)
-2018
5 Series G30 PHEV (SP41)
2019-2022
Voltage
351.4 V (nominal voltage)
355 V (nominal voltage)
Voltage Range
Min. 269 V – Max. 398 V
Min. 269 V – Max. 403 V
Battery cells
Lithium-ion
Lithium-ion
Number of battery cells
96 in series
96 in series
Number of cell modules
6
6
Cell voltage
3.66 V
3.70 V
Capacitance
26 Ah
34 Ah
Storable amount of energy
9.2 kWh
12 kWh
Usable energy
7.4 kWh
10.4 kWh
Max. power (discharge)
83 kW (short-term)
83 kW (short-term)
Maximum power (AC charging)
3.7 kW
3.7 kW
Weight
248 lbs / 112.5 kg (without retaining brackets)
261 lbs / 118.4kg (without retaining brackets)
541 mm x 1134 mm x 271 mm
Cooling system
Refrigerant R1234yf
Refrigerant R1234yf
Individual Module Dimensions
364*183*110mm (L/W/H) without BMS attached
(add c. 25mm to length or height of module for BMS)
When using SimpBMS, the original BMW BMS master module should be unplugged (blue plug). This plug should instead be used to power the BMS slave modules and for the CAN connection to slave modules. See pinout below.
It's important to note that each plug in the wiring harness has an 'in' and an 'out' pin. I.e., the 5V, GND, and CAN connections are chained from one slave module to the next. So, if for some reason you have one of the slave modules unplugged, you may need to jumper the pins in that plug or else the modules further down the chain may not work.
#7 Part Number: 61278650791 External Connector Positive
#8 Part Number: 61278650793 External Connector Negative
Pinout - Main battery connector
Pin assignments at plug connector A332*1B
Pin
Type
Description /Signal type
Connection /Measuring information
1
E
Supply, terminal 30
Power distribution box, rear
2
E
High-voltage interlock loop signal
Electric-machine electronics
3
E
Terminal 30c signal
Connector, terminal 30C
4
Not used
5
Not used
6
Not used
Yellow/Green wire inside battery - Use unknown
7
Not used
8
Not used
9
Not used
10
A
Supply
Refrigerant shutoff valve, high-voltage battery unit
11
A
Activation
12
M
Ground
Ground point
13
E/A
K-CAN bus signal L
K-CAN5 bus connection
14
E/A
K-CAN bus signal H
15
K-CAN bus signal L
Put a 120Ohm resistor across these to terminate pack
16
K-CAN bus signal H
17
Not used
18
Not used
19
Not used
20
Not used
21
Not used
22
Not used
23
E
High-voltage safety connector
24
Not used
Temperature Sensors
The temperature sensors used in the hybrid battery packs are NTC 100k/4.4 and 10k/3.4 [2].
S-Box
The BMW Hybrid Battery Pack contains a module that contains contactors and a shunt which is known as a Control Unit Module Security Fuse Box, S-Box PHEV BK, or S-Box that is now supported by the ZombieVerter. There are S-Boxes available in a number of the BMW PHEV models.
BMW S-Box
Part numbers include 8686893, 8638197, 8651068, 8681536, 8844217, 9470054, 9846612, found in the following PHEV models:
2 Series F45 Active Tourer LCI
3 Series G20
3 Series G20 LCI
3 Series G21
3 Series G21 LCI
5 Series G30
5 Series G30 LCI
5 Series G31 LCI
5 Series G38
5 Series G38 LCI
BMW S-Box High voltage connection7 Series G11 LCI
7 Series G12 LCI
X1 F48 LCI
X1 F49
X1 F49 LCI
X2 F39
X3 G01
X3 G01 LCI
X5 F15
X5 G05
MINI Countryman F60
MINI Countryman F60 LCI
Damien's notes:
Four heavy duty spade terminals provide connection for HV Battery + , - and Output + ,-
Connection of Can data and 12v power is via a white 16 pin connector on the front.
Pins 12 and 14 to +12v
Pin 3 to GND
Pin 1 CANH
Pin 10 CANL
CAN is 500K speed.
Two ids are required to run the SBox and control its contactors:
0x100 and 0x300 DLC 4 at 20ms intervals.
0x100 has a counter and CRC8 and is the main control message.
Byte 0 controls contactor function as follows :
0x62 Activates negative contactor
0x0A Activates positive contactor
0x8A Activates positive contactor and precharge relay
0xA6 Activates negative contactor and precharge relay
0x62 Activates negative and positive contactors and precharge relay
0x86 Activates precharge relay only.
Other combinations of bits in byte 0 will cause individual contactors and combinations of contactors and precharge relay to engage.
Byte 1: Counter in upper nibble running from 0x0 to 0xE. Lower nibble fixed at 0x1.Function not yet investigated.
Byte 2: fixed at 0xFF. Function not yet investigated.
Byte 3: CRC8 , Poly 0x31 ,Initial value 0x00, final XOR 0x00 , inverse both. Calculated on length of 8 bytes while message is only 4 bytes long.
0x300 can be static:
0xFF , 0xFE , 0xFF , 0xFF
Information such as Battery voltage, Current, Output voltage etc are provided over CAN making it a very versatile unit. Messages for Ah,kwh,kw etc are being investigated.
There is a video where a phev pack is dissembled it is not definitive and would recommend reading guide for VW Phev batteries first, VW Hybrid Battery Packs.
