CCS32Clara
Revision as of 22:59, 21 January 2024 by Asavage (talk | contribs) (Making Clara talk CHAdeMO on the CAN side: Various minor formatting, full-stops, minor typo fixes.)
This page is about the reference software for the OpenSource CCS Charge Controller (Foccci). CCS32Clara (also referred to as "Clara") is currently under development by the OpenInverter Community.
Here you will find documentation (or reference) how to setup clara, News on the development, diagramms, open ToDos, etc.
Clara on GitHub.
Clara in the OpenInverterForum.
Hardware Config
udcdivider dig/V 0 100 10 Division factor from ADC digits to V of external voltage measurement board
economizer % 0 100 100 Contactor economizer duty cycle. Contactors are always turned on with 12V for 1s then drop to this value. Set to 100% if your contactor has a built-in economizer
inletvtgsrc 0 2 0 0 - Charger output voltage is considered equal to charge port inlet voltage
1 - Analog input is used for measuring charge port inlet voltage
2 - Charge port inlet voltage is provided via CAN - don't forget to map something to inletvtg
lockpwm % -100 100 30 H-bridge duty cycle for operating the lock. Use negative value if lock polarity is swapped
lockopentm ms 0 10000 1000 Timeout for lock operation
lockclosethr dig 0 4095 0 Lock feedback value for closed
lockopenthr dig 0 4095 0 Lock feedback value for open - if equal to lockclosethr no feedback is assumed and lock is operated timed
Communication
nodeid 1 63 22 CANOpen node id for SDO requests
canspeed 0 4 2 Baud rate of CAN interface 0=125k, 1=250k, 2=500k, 3=800k, 4=1M
Charge Parameters
maxpower kW 0 1000 100 Absolute maximum charge power
maxvtg V 0 1000 410 Over voltage threshold. Always set about 10-20V higher then desired battery full voltage
maxcur A 0 500 125 Absolute maximum charge current
demovtg V 0 500 0 Voltage for light bulb demo. To use the board without CAN, to get an constant voltage. Is ignored as long democtrl is not STANDALONE. Only values between 150V and 250V are accepted, others are treated as zero.
demomode 0 511 0 Enables the standalone demo mode if value is set to STANDALONE. In this mode, no CAN is required and the target voltages for precharge and charging loop are taken from demovtg.
targetvtg V 0 1000 0 Charge target voltage (volatile)
chargecur A 0 500 0 Instantaneous current setpoint (volatile)
batvtg V 0 1000 0 Present battery voltage for precharge state (volatile)
enable 0 1 1 When 0 charging is stopped/not started (volatile)
Testing
locktest Actuates the lock
wd_disable Disabled the CAN timeout detection
logging Selects which modules log to the serial console
Errors
Error Description
CANTIMEOUT The message mapped to canwatchdog hasn't been received for over 1s or nothing is mapped to canwatchdog
Screenshot of CAN mapping to interface Clara CCS with CHAdeMO
  • udcdivider - Actually, here we just select some dummy item as the important bit is in the Offset field: the version. In this case I signal non-existent CDM version 10. This tells the CDM module in my car that it talks to Clara. It then includes the battery voltage in some unused message bytes - see below.
  • evsevtg - Transmits the charger's present output voltage back to the vehicle.
  • evsecur - Transmits the charger's present output current back to the vehicle.
  • opmode - Observe the weird gain - this is forged to map Clara state "CurrentDemand (13)" to CDM state "ConnectorLocked (4)". In my car's CDM module this is sufficient to initiate the charging progress. You may need to change it so that the ChargeEnable flag together with ConnectorLocked is forged (numerical value 5).
  • evsemaxvtg - Transmits the EVSE's maximum output voltage back to the vehicle.
  • evsemaxcur - Transmits the EVSE's maximum output current back to the vehicle.
  • batvtg - Transmits the present battery voltage to the EVSE. This is the special item that normally doesn't exist in CDM and that unfortunately will prevent you from using this solution with an OEM car in a safe manner. Of course, you could manually set this to some medium battery voltage like 360V, but if you arrive with a really low battery at, say, 300V this might weld your charge port contactors. You could also manually enter the battery voltage before each charging session.
  • targetvtg - Transmits the charge end voltage to the EVSE.
  • chargecur - By far the most important data item: the charge current request.
  • canwatchdog - (missing in screenshot). Map to 0x102 message at some arbitrary bits with gain=0 so it sets canwatchdog=0 whenever it is received. This makes sure charging stops if the CAN bus is disturbed.
As an additional safety measure you could connect CDM pin 4 (charge enable) to Clara's button input (at least once we added an active low mode for it). It might also be worthwhile to connect pin 7 (connection check) to the PP input for drive away protection when CDM is plugged in but not charging (again, once we have actually implemented this).
  • Pin 1 - GND
