Toyota Prius Gen3 Board
Prius Inverter
- Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
- 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
Development History
Vendors
Support
Inverter Model Numbers
- G9200-47180 (https://www.diyelectriccar.com/forums/showpost.php?p=1026169&postcount=8)
- G9200-47141 (Auris 2012, RHD)
Assembly Notes
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes. (Add details)
Source Documentation:
