Toyota Prius Gen3 Board
Prius Inverter
- Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
- 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
Development History
Vendors
Support
How To Use
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes. (Add details)
Schematics, Bill of Materials, and other documentation are available on Damien's Project Github
(Note: This is the V2, which replaces the V1 board)
(note: flesh out bill of materials here, or post changes to Damien to update his documentation directly?)
The control board takes advantage of the OpenInverter.org software (link?) for control.
Assembly notes?
