BMW F-Series Gear Lever
General Information
Much of this information is based on articles by Project Gus [1]. Thank you for reverse engineering!
Pinout and Connector
The BMW part number of the connector is 9132576-02, the TE part number is 2-929423-2 but the connector is not freely available from TE [2].
Pin | Wire Colour | Function | |
1 | NC | ||
2 | NC | ||
3 | Red | PT-CAN Low | |
4 | Blue/Red | PT-CAN High | |
5 | White/Blue | PT-CAN2 Low | |
6 | White/Yellow | PT-CAN2 High | |
7 | Green/Brown | Enable(?) | |
8 | Brown | Ground | |
9 | NC | ||
10 | Red/Blue | +12V |
CAN Bus
The Powertrain CAN Bus has a baud rate of 500kBaud.
Part Numbers
No | LHD/RHD | Description | Part Number | Vehicles Used | Status | Tested |
1 | RHD | Gear Selector Switch | 61 31 9296897 | F20, F21, F22, F23
F30, F31, F32, F33, F34, F36 |
Active | |
1 | RHD | Gear Selector Switch | 61 31 9291519 | Until 06/2013 | ||
1 | RHD | Gear Selector Switch | 61 31 9260969 | Until 08/2012 | ||
1 | RHD | Gear Selector Switch | 61 31 9253652 | Until 01/2011 | ||
1 | LHD | Gear Selector Switch | 61 31 9296896 | F20, F21, F22, F23
Active | |
1 | LHD | Gear Selector Switch | 61 31 9291517 | Until 11/2012 | ||
1 | LHD | Gear Selector Switch | 61 31 9260968 | Until 06/2013 | ||
1 | LHD | Gear Selector Switch | 61 31 9253651 | Until 01/2011 |
2 | RHD | Gear Selector Switch, Sport | 61 31 7950385 | Active | ||
2 | RHD | Gear Selector Switch, Sport | 61 31 9296899 | F20, F21, F22, F23
Until 05/2018 | X |
2 | RHD | Gear Selector Switch, Sport | 61 31 9291521 | Until 11/2012 | ||
2 | RHD | Gear Selector Switch, Sport | 61 31 9260971 | Until 07/2012 | ||
2 | RHD | Gear Selector Switch, Sport | 61 31 9253654 | Until 01/2011 | ||
2 | LHD | Gear Selector Switch, Sport | 61 31 7950384 | Active | ||
2 | LHD | Gear Selector Switch, Sport | 61 31 9296898 | F20, F21, F22, F23
Until 01/2019 | |
2 | LHD | Gear Selector Switch, Sport | 61 31 9291520 | Until 06/2013 | ||
2 | LHD | Gear Selector Switch, Sport | 61 31 9260970 | Until 06/2013 | ||
2 | LHD | Gear Selector Switch, Sport | 61 31 9253653 | Until 01/2011 |
