Toyota Prius Gen2 EVBMW Throughhole Board
The EV BMW Throughhole Board is a now-deprecated open-source board designed to repurpose Toyota Prius Gen 2 inverters by replacing the essential components of the Prius wiring harness and electronics. It runs the OpenInverter.org software for vehicle control. It was an early prototype and is deprecated in favor of a new SMD Kit from OpenInverter.org.
This is archived here for recordkeeping purposes.
History
This board was designed by Damien McGuire and sold on his EVBMW.com webstore.
While Damien had several Prius control boards designed and available, he felt they were intimidating and inaccessible at low cost to beginners because of the surface-mount components. This meant EV converters would have to buy a pre-assembled board from him at higher cost, or, already have intermediate soldering equipment and skills to tackle tiny SMD components.
The purpose of this through-hole board was to be beginner-friendly - with no surface-mount components - so that all soldering could be done by a novice at an affordable price where they would order their own components and build the board themselves using only the circuitboard from EVBMW.
An initial challenge was that the STM32 microcontroller that runs the OpenInverter software is itself a surface-mount component. The solution was the "Blue Pill" board, a popular and cheap through-hole breakout board with an onboard STM32 that could be purchased on Amazon/Ebay/etc for only a few dollars. This would be soldered onto the EVBMW board same as any other component.
After some testing, some users ran into problems with the BluePill. Perhaps the STM32 chip installed on some BluePills were non-standard knockoffs, or perhaps the board design itself didn't give full access to all the pins on the STM32 microcontroller, but for some types of motors or some things required by the software, this was a critical obstacle. (More detail needed - is this design dead, or just restricted to certain motor types, if so, which?).
Rather than find another through-hole STM32 alternative to the BluePill, several new circuitboard manufacturers at the time made it so cost effective to also populate circuitboards with SMD components that it became not only cheaper but easier for novices to just order a board with the components already mounted than to solder through-hole components themselves. So, the design was deprecated.
The first person to build a replacement design/kit for the Gen2 Prius was Johannes of OpenInverter.org, which he sells in his webstore. Damien has encouraged people to use that design, does not sell these circuitboards anymore, and considers the design a deprecated dead end.
Some people have got motors spinning and EV conversions driving with this design. (Konstantin, links?)
Old Description
How To Use
Wire Connections
Control Board Pin mapping:
| Pin # | Designation | Description |
| TB1-1 | 12v-in | Primary 12v supply from ignition on |
| TB1-2 | GND | Primary ground connection to 12v negative. All grounds are common |
| TB1-3 | 5v VCC | 5V supply from board for use with throttle pot or hall pedal |
| TB1-4 | Throttle In | 0-5v variable voltage input from throttle pedal or pot |
| TB1-5 | Regen In | 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor |
| TB1-6 | GND | |
| TB1-7 | Brake In | 12v digital input from brake light switch. |
| TB1-8 | Start In | 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used. |
| TB1-9 | For In | 12v digital input commands motor to run in forward direction |
| TB1-10 | Rev In | 12v digital input commands motor to run in reverse direction |
| TB3-1 | +12v VCC | 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it). |
| TB3-2 | GND | Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it). |
| TB3-3 | Phase U |
| TB3-4 | Phase Y | Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive |
| TB3-5 | Phase W | Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive |
| TB3-6 | Current U | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-7 | Current Y | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-8 | MG2 Enable | Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter |
| TB3-9 | MG2 Fault | Connect to MFIV for MG2 or GFIV for MG1 |
| TB3-10 | DC Bus | Connect to inverter VH to measure DC link voltage |
| TB2-1 | +5V VCC | 5v output to encoder for induction motor |
| TB2-2 | ENCA In | Encoder input A |
| TB2-3 | ENCB In | Encoder input B |
| TB2-4 | GND | Encoder ground |
| TB2-5 | HS Temp | Heatsink temp sensor input |
| TB2-6 | MOT Temp | Motor temp sensor input |
| TB4-1 | GND | Common ground |
| TB4-2 | Main Con | Main HV contactor control low side switch |
| TB4-3 | Precharge | HV precharge contactor control low side switch |
| TB4-4 | +12 V VCC | Spare 12v output |
| TB4-5 | CAN L | Can bus low signal |
| TB4-6 | CAN H | Can bus high signal |
