VW Touran Conversion
Revision as of 20:53, 12 May 2019 by Johu (talk | contribs) (Faults)
I will start loosely collecting infos on the VW Touran from 2004.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I will have to look into reading the pedal directly. Here is its pin map:
Throttle pedal pin map
Pin # Color code Function
1 green/white 5V
2 yellow/green 5V
3 brown/blue GND
4 white/blue Throttle 1 0.75V-4.1V
5 green/blue GND
6 blue/black Throttle 2 0.38-2.05V
ECU connector
Touran ECU with Rev 2 main board
11 - Throttle GND (Pin 5)
12 Throttle 2 out (Pin 6)
13 Throttle 5V (Pin 1)
33 Throttle GND (Pin 3)
34 Throttle 1 out (Pin 4)
35 Throttle 5V (Pin 2)
31 Vacuum sensor 5V
37 Vacuum sensor GND
83 Vaccum sensor signal
86 Ignition On?
87 While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU
67 CANL
68 CANH
Power steering
CAN bus
Some Touran CAN messages
COB Id Len Function Notes
0x380 Byte 2: 0-0xFE throttle position Produced by ECU, so n/a when removed
0x1A0 1 Byte 1, Bit 3: Brake pedal switch Produced by whoever
0x280 Bytes 2 and 3: RPM*4 Produced by you, Controls the rpm gauge
0x480 8 Byte 6, Bit 2: Cruise light, Byte 1, Bit 3: EPC, Bit 4: engine Controls various indicator lights
0x288 Byte 1: Temp Gauge 0.75x temp - 48 Produced by you, Controls temp gauge
0x38A Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+
0x572 Byte 0, Bit 3: Key switch in start position
Faults
After powering up the engine I got two error messages: STOP low coolant and something about an oil sensor. The first can be solved by filling the reservoir with water. The second is probably down to the missing oil level sensor. I will investigate. Update on oil level warning: I fitted a 1k2 Ohm resistor from pin 2 to pin 3 (generates 2.5V "oil level") and the warning is gone.
Also the oil pressure switch needs to be faked. Below about 800rpm now oil pressure must be reported. Above 800rpm it must be. Otherwise you get a "STOP!" message. There is a few seconds time to gracefully switch over. Oil pressure switch is on plug on the front left, will add a picture later.
