Tesla Model S/X GEN2 Charger
The Tesla GEN2 is a single/three phase 10kW AC charger that was fitted in the Model S from 2012 until it was replaced in the 2016 'facelift' model with GEN3.
One or two GEN2 chargers are installed beneath the rear seats.
Replacement control boards
replacement control board https://github.com/damienmaguire/Tesla-Charger
Programing
you'll need a st-link v2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
st-link programming utility: https://www.st.com/en/development-tools/stsw-link004.html
stm32_loader.hex https://openinverter.org/forum/viewtopic.php?f=7&t=1119
Two options:
- Charger_gen2_v5.hex https://github.com/damienmaguire/Tesla-Charger/tree/master/V5/Software/Binary
- Or commercial software: Link to be added stm32_charger.hex
This will ask to open a file, you choose: "stm32_loader.hex" from OpenInverter.org, download ahead of time. This will change what shows up in the viewing window.
Future updates can be done via wifi. (must have esp8266 wifi module programed https://openinverter.org/forum/viewtopic.php?f=5&t=8 )
External CAN bus
The V5 version of the board has no connection to the external CAN bus but you can add it with to bodge wires as shown in the picture. You will find CANH and CANL on the 3 pin header underneath the wifi module. Route them over to CONN6 as shown. The upcoming revision will not need this modification.
If the charger is the first/last device on your CAN bus there is nothing else to do. If it is somewhere in the middle you have to remove the bus termination resistor R1.
Before doing this be aware that all internal CAN traffic is also seen on the external CAN bus.The following IDs are already used and mustn't used by any other device on the bus:
207, 209, 217, 219, 227, 229, 237, 239, 247, 249, 327, 329, 347, 349, 357, 359, 367, 368, 369, 377, 379, 537, 539, 717, 719, 20B, 21B, 22B, 23B, 24B, 32B, 34B, 35B, 36B, 37B, 42C, 43C, 44C, 45C, 53B, 71B.
ID | Direction | Byte 0 | Byte 1 | Byte 2 | Byte 3 | Byte 4 | Byte 5 | Byte 6 | Byte 7 |
0x102 | Receive by charger | DC voltage limit MSB | DC voltage limit LSB | DC current set point | Bit 1: enable charging | SoC | |||
0x108 | Transmit by charger | Version=0 | Max DC voltage MSB | Max DC voltage LSB | Max DC current | ||||
0x109 | Transmit by charger | Version=0 | DC voltage MSB | DC voltage LSB | DC current | 0 when off, 5 when charging |
Commercial charger firmware
In addition to the open source firmware there is also a commercial firmware. It adds advanced features:
- Support for the standard open inverter web interface
- Parameter handling as known from the inverter firmware (see picture)
- Spot value handling like inverter including plotting, gauges, and logging
- Over the air update like inverter
- DC current control
- CAN control as described above
The firmware requires the board to be flashed with stm32_loader.hex. An Olimex MOD-ESP8266 must be programmed with the openinverter web interface. See here how to flash it to the module. With that done, future updates will happen via the web interface.
Registration
If bought a fully assembled V6 (?) board from the EVBMW webshop you can skip this step.
The firmware will work without registration but charging time is limited to 5 minutes. To overcome this, a board-specific pin must be bought. In order to do this the firmware and web interface must be installed and working.
Go to the openinverter webshop and check out as many pins as you need. When checking out add the serial number(s) of your board(s) in the order comment. You will find the serial number on the bottom of the page as last spot value.
You will then receive an email containing one pin for each board. Enter the pin in the web interface in the "pin" parameter. When the pin is correct it will be automatically saved to flash and your board is ready to be used.
Commercial firmware usage manual
We will go over all of them.
idclim
This parameter is mainly relevant for CAN operation. It is transmitted via CAN to let the vehicle know how much DC current the charger can deliver. Each charger module maxes out at about 15.5A so the maximum total charging current is 46.5A. Since the total power is also limited to 10 kW it depends on the output voltage as well. There is no need to be exact on this, the firmware will automatically limit the AC input current to each charger to the hardware maximum.
iaclim
This is the per-phase AC current limit. When charging from a 3-phase outlet (see below) each module will be allowed this current. When charging from single phase, this current will be equally distributed between the enabled chargers.
idcspnt
chargerena
udcspnt
udclim
timelim
threephase
Specify that the charger is connected to a 3-phase outlet. This allows each module to operate at the current limit specified by "iaclim". Otherwise iaclim is spread equally between the enabled modules.
autostart
This is meant to run the charger off an EVSE. It will start charging as soon as it detects proximity of a Type-2 or Type-1 charging cable. It will also read the current limit of the cable and the current limit transmitted via the Type-2 pilot signal and obey it. When operating off a plain wall outlet, set to off.
type2cable
When on, expect Type-2 signalling as described above. Otherwise Type-1.
cancontrol
When on, expect charging instructions via CAN message 0x102 as described above. Charging will start when the enable bit is set. when no CAN message is received for 1s, charging will stop. Note that the digital enable input also needs to high to allow charging.
idckp/idcki
pin
