CCS32Clara
Revision as of 18:58, 5 April 2024 by Johu (talk | contribs) (Parameters)
Disclaimer: This Page is still work in progress! Any information written here is a draft only and should be handled as such. Contributions are more than welcome. If you have questions, please ask them in the discussion section of the page or in the OpenInverter Forum.
This page is about the reference software for the Fully OpenSource CCS Charge Controller (Foccci). CCS32Clara (also referred to as "Clara") is currently under development by the OpenInverter Community.
Here you will find documentation (or reference) on how to setup Clara, News on the development, diagrams, open ToDos, etc.
Clara on GitHub.
Clara in the OpenInverterForum.
Configuring Clara via CAN
Clara exposes only one single CAN interface for vehicle communication and initial configuration. So we need a CAN counterpart to talk to it.
There are two main approaches to this: a) use a command line tool [1] or b) use an ESP based CAN module [2]
Both ways require knowing Claras so called Node Id (similar to an IP address on a local network). By default this is 22. You can enter this node id on the bottom left navigation bar.
Hardware Config
UdcDivider dig/V 0 100 10 Division factor from ADC digits to V of external voltage measurement board
InletVtgSrc 0 2 0 0 - Charger output voltage is considered equal to charge port inlet voltage
1 - Analog input is used for measuring charge port inlet voltage
ppvariant 0 9 0 Various circuit variations exist for PP resistor measurement. "1" is correct for the latest hardware
WakeupPinFunc 0 4 0 Configure what the wakeup pin does. TODO: describe below
Communication
CanSpeed 0 4 2 Baud rate of CAN interface 0=125k, 1=250k, 2=500k, 3=800k, 4=1M - when configuring this != 500k you will loose communication to the ESP web interface!
Charge Parameters
MaxPower kW 0 1000 100 Absolute maximum charge power
MaxVoltage V 0 1000 410 Over voltage threshold. Always set about 10-20V higher then desired battery full voltage
MaxCurrent A 0 500 125 Absolute maximum charge current
ChargeCurrent A 0 500 0 Instantaneous current setpoint (volatile)
enable 0 1 1 When 0 charging is stopped/not started (volatile)
Testing
Spot values
Name Unit Description
version
lasterr Last detected error
StopReason
checkpoint
cpuload
Errors
Error Description
CANTIMEOUT The message mapped to canwatchdog hasn't been received for over 1s or nothing is mapped to canwatchdog
Making Clara talk CHAdeMO on the CAN side
Screenshot of CAN mapping to interface Clara CCS with CHAdeMO
  • UdcDivider - Actually, here we just select some dummy item as the important bit is in the Offset field: the version. In this case I signal non-existent CDM version 10. This tells the CDM module in my car that it talks to Clara. It then includes the battery voltage in some unused message bytes - see below.
  • opmode - Observe the weird gain - this is forged to map Clara state "CurrentDemand (13)" to CDM state "ConnectorLocked (4)". In my car's CDM module this is sufficient to initiate the charging progress. You may need to change it so that the ChargeEnable flag together with ConnectorLocked is forged (numerical value 5).
As an additional safety measure you could connect CDM pin 4 (charge enable) to Clara's button input (at least once we added an active low mode for it). It might also be worthwhile to connect pin 7 (connection check) to the PP input for drive away protection when CDM is plugged in but not charging (again, once we have actually implemented this).
  • Pin 1 - GND
