VW Touran Conversion
I started this conversion in November 2018 with a 2004 VW Touran 1.6 petrol. It uses the EM57 Nissan motor (found also in Leaf and eNV-200) with its original inverter. The motor is bolted to the original 6-speed gearbox which seems to handle the torque fine. Also Nissans original DC cable, DC contactors, BMS and ChaDeMo socket is used and integrated into the vehicle.
The conversion heavily uses the existing motor CAN bus. A custom board has been fitted into the original ECU enclosure which is a nice junction point of various signals like throttle pedal, vacuum sensor and so on. The board handles VW specific CAN messages, Nissan Leaf BMS CAN messages and the ChaDeMo protocol. Last but not least it controls the inverter.
{{#drawio:TouranTest|type=svg|max-width=500px}}
Mechanical work
The obvious first step is to remove the combustion engine. There are various tutorials for that, I will only go into the specifics on EV conversion.
- Unplug the engine harness from the ECU - this allows you to leave most connectors on the engine in place and just remove it with the complete harness - good for resale
- Consider keeping the ECU to place your own logic inside its enclosure
- Do not use force! You will reuse many connectors so don't destroy them
- The only thing you can safely cut is the fuel pipes :)
- Have someone empty the A/C - it's a vary unpleasant spray if you don't. Don't ask me how I know.
Transmission coupling plate
The Inverter mount collides with the transmission bell so I had to cover quite some distance to avoid it. To save on material I used box section profiles 4mm walls, 80x40mm. Bolted them together with a 100x50x40 U-profile and bolted all that to the motor. I had to make a little cutout for the drive shaft.
The bell housing plate started life as a 350x350mm 15mm plate that we cut to shape with a jigsaw. Afterwards it turned out I should have gone for 20mm as the whole assembly was shorter than the shaft coupler - forcing me to add another 5mm aluminium in between.
Shaft coupler
While the coupling plate is rather ham fisted the shaft coupler is not - because I wasn't in charge ;) At its core is a KTR Rotex GS38 jaw coupling. On one side is an assembly that embraces the spline extracted from the VW clutch on the other side it bolts onto a Nissan spline that used to be sold by New Electric but the stopped making it.
I didn't put much effort into aligning, just put the transmission on top of the motor, drew the hole marks as accurately as possible, drilled, tapped. Even took the whole thing apart inside the engine bay. Lets hope there is no backlash.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I am reading the pedal directly. Here is its pin map:
Pin # | Color code | Function |
1 | green/white | 5V |
2 | yellow/green | 5V |
3 | brown/blue | GND |
4 | white/blue | Throttle 1 0.75V-4.1V |
5 | green/blue | GND |
6 | blue/black | Throttle 2 0.38-2.05V |
ECU connector
7 | white | P4.4 (Enable DC/DC Converter) |
11 | - | Throttle GND (Pin 5) |
12 | Throttle 2 out (Pin 6) | |
13 | Throttle 5V (Pin 1) | |
33 | Throttle GND (Pin 3) | |
34 | Throttle 1 out (Pin 4) | |
35 | Throttle 5V (Pin 2) | |
31 | Vacuum sensor GND | |
37 | Vacuum sensor 5V and P5.7* | |
53 | P5.5 (I use it for fuel level signal A) | |
54 | P5.2 (I use it for fuel level signal B) | |
55 | gn | P4.2 (Oil pressure simulation) |
56 | bk | P4.1 (Enable DC/AC 230V converter) |
76 | P5.1 (I use it for DC switch switched GND) | |
77 | rd/gr | P4.6 (Vacuum pump switched GND) |
78 | gr/wt | P4.5 (Type-2 plug connected) |
80 | P5.4 (I use it for CANL towards Nissan BMS) | |
81 | P5.3 (I use it for CANH towards Nissan BMS) | |
83 | Vaccum sensor signal | |
86 | Ignition On - provides enough power to run the main board | |
87 | While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU | |
67 | CANL | |
68 | CANH |
*Underneeth the car there is a 10-pole connector that used to plug in to some exhaust sensor controller. I call this "P5".
P5.7 is connected to the main board "VCU" 5V rail. I make use of this to power the VCU from the ChaDeMo charger.
In the front near the 12V battery there is another 6-pole connector that I call "P4".
Power steering
As soon as you produce CAN message 0x280 it expects rpm to be above about 600rpm, otherwise there is no power steering.
CAN bus
COB Id | Len | Function | Notes |
0x1A0 | 1 | Byte 1, Bit 3: Brake pedal switch | Produced by whoever |
0x280 | Bytes 2 and 3: RPM*4 | Produced by you, Controls the rpm gauge. Must be > 600 for power steering to work | |
0x284 | 6 | Byte 0, 1: Counter 0-F in each
Byte 2-5: 0 |
20ms. Can also be 8 bytes long. |
0x288 | Byte 0: sequence 0x27, 0x46, 0x8F, 0xD7
Byte 1: Temp Gauge 4/3 x temp + 48 |
Produced by you, Controls temp gauge. Gain 4/3, offset 48 | |
0x380 | 8 | Byte 0: 0
Byte 1: 0x65 Byte 2: Throttle 0-0xFE Byte 3-6: 0 Byte 7: Throttle delayed or filtered maybe + idle throttle as it's never 0 |
It's not actually that constant but apparently sufficient for DSC |
0x38A | Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+ | ||
0x480 | 8 | Byte 0: sequence 0x10, 0x68, 0x94, 0xC0
Byte 1, Bit 2: EPC, Bit 3: engine Bytes 3,4: Consumption signal - incremental. Increasing by 28 per 10 ms results in 10l/h Byte 5: 0 Byte 6, Bit 2: Cruise light, Bit 4: Message "Motorstörung Werkstatt!" Byte 7: XOR of Bytes 0-6 |
Controls various indicator lights and fuel consumption display |
0x488 | 8 | Byte 0: Counter 0-F << 4 + 8
Byte 1-4: 21, 21, 7E, A6 Byte 5-6: 0 Byte 7: Counter 0-F << 4 |
0x572 | Byte 0, Bit 3: Key switch in start position | ||
0x580 | 8 | Byte 0: 0x80 + counter 0-F
Byte 1, 2: 0 Byte 3: sequence 0x0f, 0x28, 0x7f, 0x28 Byte 4: sequence 0x1e, 0x10, 0x00, 0x10 Byte 5: sequence 0x70, 0x56, 0xf0, 0x56 Byte 6: sequence 0x0c, 0x48, 0xa7, 0x48 Byte 7: sequence 0x46, 0x90, 0x28, 0x90 |
100ms |
Software here: https://github.com/jsphuebner/stm32-car
CAN bus tap
I wanted to tap into the CAN bus without cutting wires. The power steering assembly is connected via a 6-pole "VW" connector that has the CAN bus on it. The respective part numbers are 1J0973713 and 3B0973813. So I looped through the 4 signals irrelevant to me and directed the CAN bus towards the inverter. The Nissan wiring loom also has a CAN bus return that I then looped back to the power steering.
Battery Integration
As opposed to the original plans I currently only mounted one full Nissan Leaf pack in the fuel tank space. I used the existing 5 M8 holes that used to hold the fuel tank and part of the exhaust. In addition I drilled 3 holes into the seat carrying structure that exit exactly between the two battery bricks. Another 3 M10 screws fix the two bricks to the chassis there. So 8 bolts fix the mounting angles to the chassis.
The mounting angles are screwed into the battery brick with 2 M6 bolts each. There are 11 mounting angles, so 22 M6 screws fix the batteries to the mounting angles.
Positive and negative exit on the cars driver side. Positive passes through Nissans service disconnect jumper that also contains a 225A fuse. Next up the 2 poles connect to Nissans original DC switch gear in the exhaust tunnel and connect to the inverter using Nissans original DC cable.
I reused the original spaghetti wires and Nissans BMS (they call it LBC). It lives on top of the front battery brick. Its current sensor is bolted onto the positive DC switch in the exhaust tunnel. It also still monitors the safety disconnect. Its power supply and communication wires run to the fuel tank service hole under the rear seats. From here it connects to the motor CAN bus. It also runs at 500kbit/s and has no mutual object ids.
Fuel Gauge
Unfortunately the fuel gauge cannot be controlled via CAN bus. Instead there is a special fuel controller under the rear seats. It has a black ground cable, a red cable that used to enable the fuel pump and three smaller wires that used to connect to an analog pot inside the fuel tank. The instrument cluster is very picky about the correct resistance and will simply bottom out the gauge if out of range. Afterwards the instrument cluster must be restarted to forget the error.
Luckily the resistance is measured vs. GND, i.e. the two sense wires (the darker ones, the red is GND) must be pulled to GND via some resistance. I use a pair of BC547 NPN transistors that connect to a 17kHz PWM via a 20Hz low pass filter. Thus their "resistance" to ground can be controlled via the dutycycles of those PWMs. When the resistance on both is equal, about 500 Ohms, the fuel gauge is centered. if it goes lower on one it must become higher on the other one accordingly.
In VCU a base duty cycle of 34% is generated, with one channel falling 0.06% per % SoC and the other rising at the same rate.
Fast Charging
I decided to use ChaDeMo for fast charging since the Nissan drive stack came with a ChaDeMo connector and ChaDeMo is pretty simple to implement. I had to twist the socket by 90° because that was the only way to fit it. I soldered a shielded Ethernet cable to the control lines and extended the power cables to reach the relay cluster in the exhaust tunnel. I used Nissans original charge port relays that I extracted from the PDM (the module on top of the drive stack). They come with a neat economizer circuit that I use as is.
Next I had to go about implementing the protocol. The charger will supply the car with 12V and up to 2A. This current must suffice to operate the input relays.
Next up is drive away protection, I decided on a simple hardware logic: when the plug is inserted, the DC relays will not close or be opened if they are already closed. It is a bit dangerous to the relays because they may be forced to interrupt current e.g. if your HV cabin heater is still on at that time. ChaDeMo pulls a pin to GND when inserted. I use that to switch on a small PNP transistor which in turn switches an NC relay which in turn cuts 12V power supply to DC relays. You can see the small relay below the large caps.
Next up the "charge allow" signal. It must be pulled to ground to allow the charger to start. I misused one of the fuel gauge signals for the purpose. It switches on a PNP/NPN pair.
Finally the CAN part. I decided to implement the logical protocol on the existing VCU as it has a CAN interface which extends to the back of the car anyway (because of the BMS). It is powered up by the power that ChaDeMo delivers and detects the charge situation by checking the inverter voltage - it will be 0 because the inverter is not powered up.
Now comes the challenge of using the CAN bus for ChaDeMo. Luckily it is also 500kbit/s and there are no mutual IDs between ChaDeMo and the BMS. But we can't just connect it to the charge port as is because the charger adds additional termination and thus the bus would be terminated 3 times. Also it is not good practice to leave parts of the bus dangling about. So I build a CAN repeater that creates a new physical bus.
The VCU now talks to the BMS which constantly updates the charge current limit. That info is simply relayed to the ChaDeMo charger. If connection to the BMS is interrupted, the charge control signal is turned off.
Trap for young players: The 5V supply to the VCU seems to leak back into parts of the 12V system. So the vacuum pump, also controlled by the VCU turned on and depleted the 5V supply. So I added extra logic in firmware to keep vacuum pump off in charge mode.
DC/DC converter
To keep the 12V system alive, you need to replace the alternator with something else: a DC/DC converter that converts our 380V to 13.8V. Luckily, most off-the-shelve switch mode power supplies work in that voltage range. I use a Meanwell SP-750-12. It is specified up to 370V DC but doesn't complain about 395V either. I replaced its cheap fan by a Papst one to keep the car silent. Also cranked up its voltage adjuster to maximum which is 13.9V.
I added an output relay, otherwise the supply will actually drain your 12V battery when off. The relay is switched on together with the main DC switch. I added another relay to the input, otherwise the DC/DC converter will start up via the precharge resistor and destroy it after a while.
Update: I installed a PTC cabin heater and the 63A of the Meanwell supply was no longer appropriate. So I installed an Ampera DC-DC converter capable of 150A. It is connected to CAN bus so the VCU can set its output voltage. The enable pin is simply connected to ignition 12V. I could do away with the two relays. The unit is bolted on top of the inverter and is air cooled through a small slot in the front grill. That means it does heat up quite a bit when running the heater during standstill.
I tapped into the CAN bus by pulling the round connector from Nissan's PDM (power deliver module, the one that normally sits on top of the inverter). So no that is no longer dangling around unused.
Update2: I fitted an Outlander OBC that also contains a DC-DC converter. I connected it to the car using Nissans rounds PDM connector. That way I can neatly route cables right to left via vacant cables in Nissans wiring loom (I knew why I didn't strip it back then!)
Faults
After powering up the engine I got two error messages: STOP low coolant and low oil level. The first can be solved by filling the reservoir with water. The second is solved by turning off oil sensor support in the instrument cluster.
I programmed the instrument cluster to ignore the missing sensor. You need a CAN OBD adapter with matching software. Then in adaptation channel 39 change value to 0 (=sensor not present). Found here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Instrument_Cluster
Counter part of the shown connector has part number 3C0973837.
DSC light
A bit harder to fake was the messages for the ABS/DSC system. It seems all messages originally produced by the ECU need to be on the bus. That is Ids 0x280, 0x284, 0x288, 0x380, 0x480, 0x488, 0x580 and 0x588. So far it seems their content doesn't have to match exactly. See table above.
More connectors
There is another 6-pole connector whos counterpart has part number 1J0973833. Four of its pins end up inside the ECU so it is useful for getting "miscellaneous" signals out of it. I put the oil pressure simulation and DC switch on it.
There is another 10-pole connector underneath the car that has quite a few pins ending up in the ECU. It used to be connected to some kind of exhaust sensor. The mating plug has part number 6X0973815.
I will use it for DC switch, fuel tank fill level simulator, and CAN bus (towards Nissan LBC). I'm doing the latter because the current CAN bus layout gets disturbed by EMI.
