Mitsubishi Outlander AC Compressor
The Outlander PHEV has a CAN bus controller AC compressor. One thing to note, your old system components will likely need flushing of the old oil as it's damaging to compressor motor wiring lacquer. It can cause shorts. When getting your system refilled, it needs to contain compatible lubricating oil, POE MA68EV is listed in the manual, likely the same as other hybrids/electric cars.
| Weight | 6.2kg |
| Length | 19cm |
| Height | 20cm |
| Width | 12cm |
Low Voltage Connection
The mating connector is Sumitomo 6189-0126 https://www.auto-click.co.uk/6189-0126?search=90980-10942 and the pinout is the same as the water heater. Connector also available cheap on aliexpress.
