Volkswagen Heater
General Information
Operating Voltage and Conditions
280VDC...450VDC
HV connector HVA 280 KEY_E from TE
  • +HV near to the body,
  • -HV far from the body
LV Connector 1J0973714
  • Pin 1 is permanent 12V
  • Pin 2 is GND
  • Pin 4 is LIN
LIN Bus Communication
Control and Answer Messages from/to Heater[1]
ID Description Length Checksum Type Byte 0 Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7
28 Control, every 50ms 2 ?? Power Last bit: Start/Stop
48 Feedback 8 ?? Power:
13 = 770W
26 = 1540W
?? ?? ?? ?? ?? Temperature in Temperature out
Part Numbers
VW heater P/N are:
  • 3Q0963231A
  • 3Q0963231C
  • 3Q0963231E
HV cable P/N is 3Q0971475 or 5Q0971475.
LV connector looks like it is Webasto 1J0973714 8P type.
2. http://datasheets.dbk-worldwide.com/EN/Datasheets/WireHeaters/DBKITM_HV%20Water%20heater_eng.pdf
  1. http://datasheets.dbk-worldwide.com/EN/Datasheets/WireHeaters/DBKITM_HV%20Water%20heater_eng.pdf
