Toyota Prius Gen2 Board
Revision as of 15:13, 7 January 2022 by Crasbe (talk | contribs) (Added categories to the page to allow for better navigation)
Prius Gen 2 Inverter Montage
  • Large part availability, Prii have been made in large numbers for 20 years and spares are inexpensive.
  • Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp)
(Inverter Side)
(See pictures to the right)
Wire Color
(Harness Side)
1 vacant
2 GIVA MG1 Phase Current V LightGreen White
3 GIVB MG1 Phase Current V Purple-Red Black
4 GUU MG1 PWM U - Speed Signal Wave Blue Black
5 GVU MG1 PWM V - Speed Signal Wave Blue-Red Green
6 GWU MG1 PWM W - Speed Signal Wave Yellow Yellow
7 MIVA MG2 Phase Current V LIghtGreen-Black Green
8 MIVB MG2 Phase Current V Purple-Yellow White
9 MUU MG2 PWM U - Speed Signal Wave Blue-Black Black
10 MVU MG2 PWM V - Speed SIgnal Wave Blue-Yellow White
11 MWU MG2 PWM W - Speed Signal Wave Yellow-Black Red
12 VH Inverter Capacitor Voltage Purple Yellow
13 CPWM Boost converter PWM switch signal Blue Black
14 CT Boost converter temperature sensor Green-Red Red
15 VL Boost converter input voltage Purple-White Yellow
16 GINV Inverter Ground Black-White Yellow
17 vacant
18 GIWA MG1 Phase Current W Grey Red
19 GIWB MG1 Phase Current W Grey-Black Green
20 GSDN MG1 Shutdown Brown-Black Red
21 GIVT MG1 Inverter Temperature Green-Black White
22 GFIV MG1 Inverter Fail White-Grey Grey
23 MIWA MG2 Phase Current W Grey-Green Red
24 MIWB MG2 Phase Current W Grey-Red Black
25 MSDN MG2 Shutdown Brown Green
26 MIVT MG2 Inverter Temperature Green Light Blue
27 MFIV MG2 Inverter Fail White Green
28 OVH Overvoltage Pink Brown
29 CSDN Boost converter shutdown signal Brown-White White
30 FCV Boost converter fail signal White-REd White
31 OVL Boost converter over voltage signal Pink-Blue Black
32 GCNV Boost converter ground Black-Red Green
DC-DC Converter
Prius Gen2 DC-DC connections.
1 IGCT 12v+ Blue
2 ID1 Not Needed Purple
3 S B+ (opt) White
4 NODD 0-5v+ Ppl/Gld
5 VLO Not Needed Blue
6 Vacant
Inverter Cooling
Wiring
Connector Male Female
C5 90980-10987 90980-10987
B+ (DC-DC output) 90980-11963
32-pin connector TE 1318747-1 (& 1123343-1 for pins)
28-pin connector (on inverter logic board) TE 1565380-1 (& 1123343-1 for pins)
Through Hole Control Board
Prius Board v1
How To Use
Wire Connections
Prius Control Board - Wiring Map (click to see fullsize details)
Control Board Pin mapping:
TB1-1 12v-in Primary 12v supply from ignition on
TB1-2 GND Primary ground connection to 12v negative. All grounds are common
TB1-3 5v VCC 5V supply from board for use with throttle pot or hall pedal
TB1-4 Throttle In 0-5v variable voltage input from throttle pedal or pot
TB1-5 Regen In 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor
TB1-6 GND
TB1-7 Brake In 12v digital input from brake light switch.
TB1-8 Start In 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used.
TB1-9 For In 12v digital input commands motor to run in forward direction
TB1-10 Rev In 12v digital input commands motor to run in reverse direction
TB3-1 +12v VCC 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it).
TB3-2 GND Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it).
TB3-3 Phase U
Phase U output. Connect to Inverter MUU terminal for MG2 inverter drive or GUU for MG1 inverter drive
TB3-4 Phase Y Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive
TB3-5 Phase W Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive
TB3-6 Current U Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-7 Current Y Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-8 MG2 Enable Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter
TB3-9 MG2 Fault Connect to MFIV for MG2 or GFIV for MG1
TB3-10 DC Bus Connect to inverter VH to measure DC link voltage
TB2-1 +5V VCC 5v output to encoder for induction motor
TB2-2 ENCA In Encoder input A
TB2-3 ENCB In Encoder input B
TB2-4 GND Encoder ground
TB2-5 HS Temp Heatsink temp sensor input
TB2-6 MOT Temp Motor temp sensor input
TB4-1 GND Common ground
TB4-2 Main Con Main HV contactor control low side switch
TB4-3 Precharge HV precharge contactor control low side switch
TB4-4 +12 V VCC Spare 12v output
TB4-5 CAN L Can bus low signal
TB4-6 CAN H Can bus high signal
New SMD control board with enclosure and designated pinouts
Please add pictures and description.
Enclosure Details
The SMD board was designed to work the the following enclosure and connectors:
Description Part Number Data Sheet
Cinch Header 12 + 20 5810132011 https://www.mouser.co.uk/datasheet/2/643/Bel_07192016_Modice%20ME-MX-1216545.pdf
Modice Enclosure 5810130075 https://www.mouser.co.uk/datasheet/2/643/dr-CCS-ICE-5810130065-75-1551287.pdf
Molex 12-Pin Connector 0334721202 https://www.mouser.co.uk/datasheet/2/276/0334721202_CRIMP_HOUSINGS-162938.pdf
Molex 20-Pin Connector 0334722001 https://www.mouser.co.uk/datasheet/2/276/0334722001_CRIMP_HOUSINGS-162940.pdf
WIFI Module MOD-WIFI-ESP8266 https://www.ebay.co.uk/itm/194313893813?epid=2280174677&hash=item2d3e02b7b5:g:v-MAAOSw4ulhJ1wg
WIFI Pins 10-way IDC Box Header Connector https://www.ebay.co.uk/itm/153727472406
Pin Mapping - Note : Smaller 12-pin socket is the interface to the inverter & 20-pin to the motor
32 Pin Main white connector Gen 2 Inverter emplacement
20 - Pin socket
Pin#01 - ENC_B/S3
Pin#02 - S1S4
Pin#03 - ENC_A/S2
Pin#04 - R1
Pin#05 - R2
Pin#06 - 5V
Pin#07 - THROTTLE 1
Pin#08 - THROTTLE 2
VCU to Prius Gen2 wiring v1.1
Pin#09 - START_IN (12V)
Pin#10 - BRAKE_IN (12V)
Adapter Board Pin out locations
Pin#11 - FORWARD_IN (12V) (1, 2 or 3 way switch)
Pin#12 - REVERSE_IN (12V) (1, 2 or 3 way switch)
Pin#13 - Motor Temp -
Pin#14 - Motor Temp +
Pin#15 - DC (HV) Switch Control (Ground signal)
Pin#16 - Pre-ChARGE Control (Ground signal)
Pin#17 - CAN L
Pin#18 - CAN H
Pin#19 - Ground
Pin#20 - 12V "Ignition"
12 - Pin socket ( starts at pin number #21) - Corresponding pin on Main White 32 pin Inverter connector is in brackets.
Pin#21 - GIVA (2)
Pin#22 - MIVA (7)
Pin#23 - GIWA (18)
Pin#24 - MIWA (23)
Pin#25 - VH (12)
Pin#26 - MIVT (26)
Pin#27 - MFIV (27)
Pin#28 - MUU (9)
Pin#29 - MVU (10)
Pin#30 - MWU (11)
Pin#31 - CPWM (13)
Pin#32 - GINV/GCNV (16/32)
Connect MSDN Pin#25 in inverter (not 25 on controller) permanently to 12V to enable the MG2 Inverter (can be tied to same 12v source as "I9")
Connect CPWM to 12V via a 470 Ohm resistor for charge mode.
Connect the 2-pole white power connector ("I9") inside inverter to 12V and Ground to power up inverter electronics.
Make sure to connect Pin #32 and GINV/GCNV to vehicle ground.
Initial Set up
Step 1 : Solder relevant (and included) connector pins to the Adapter Board
Step 2 : Plug in Wifi Adapter and connect ONLY Pin#19 - GROUND and Pin#20 - 12 Volts power supply
Confirm PWR LED lights up along with WIFI LED. Confirm ALIVE LED flashes.
Step 3 : Connect computer/laptop to the wifi network (Example - Inverter 7)
Step 4 : Go to browser toolbar and type in 192.168.4.1 + Enter. (allow pop ups/Trusted site). Confirm Web based Interface appears and list of parameters appear.
If parameters appear, you are now connected to the Adapter board and the Web based Interface - Congratulations - You are now in the Matrix !
Step 5 : Wire up 12 Pin SMD board connector to corresponding 32 Pin Inverter connector, permanent 12 volt supply to Pin #25 (MSDN) of Inverter, and 12V and Ground to 2-pole Inverter connector (next to main 32 pin white connector)
Step 6 : Connect fused 12 volt and Ground to HV Inputs (battery), along with 55 watt light bulb in series (resistor) on the Positive line
Step 7 : Connect fused 12 volt power supply for SMD board , Pin #25, and Inverter 2-pole connector - You are now set up for basic Open Loop motor spinning!
Step 8 : Connect 21 watt light bulbs in Delta connection to the 3 PWM outputs in Inverter (no motor) - https://openinverter.org/forum/download/file.php?id=4273&mode=view
Step 9 : Web Interface Basic parameters set up - to confirm PWM outputs : Full boost with 12v supply, default forward, ampnom @ 70%, and fslipspnt @1 Hz. Select - "Start Inverter in Manual Mode" Confirm flashing lights.
Step 10 : Connect motor phase wires to inverter PWM outputs. Repeat Step 9 and change "fslipspnt" by 1 unit at a time, until motor spins smoothly. (I noticed Light bulb resistor on HV line lights up when no spinning) along with high current values. Once you have the motor spinning, continue to increase the "fslipspnt" value whilst monitoring the current (ampmeter on PWM output wire) You will also notice the light bulb starting to fade untill there is no more light. Optimal motor spinning in Open Loop Mode ! (these values are related to a 12 volt HV supply - re using these parameters is still to be verified at greater supply voltages)
Software
The Control Board runs Open Inverter software. A set of known-good default inverter parameters can be found here: https://openinverter.org/wiki/Configuration_Files#Toyota_Prius_Gen2_Inverter
Do NOT program a deadtime value for the Gen2 inverter. It only uses 1 PWM per phase and the inverter itself generates a low-side and high-side signal WITH deadtime.
Charging
Relevant Parameters
Charge mode:Buck
Chargecur: 1.5
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
Relevant Pins
  • CSDN (pin 29 on inverter)
    • Shuts down high and low IGBTs when fed 12v, via 470R
    • When CSDN is HIGH both IGBTs are OFF.
  • CPWM(pin 31 on control board, 13 on inverter)
    • Enables charge mode when fed 12v via 470R
    • When CPWM is HIGH, the LOW side IGBT is on(shorts out battery), when CPWM is LOW the HIGH side IGBT is on.
  • Forward and reverse (11 and 12 on control board)
    • Both must be high to enable charging
  • DCSW switch(15 in control board)
    • Controls DC relay switch.
Physical setup
  • 240v AC plugs into two MG1 phases, with a precharge resistor always on.
    • Relay controlled by DCSW pin connected to ground side of relay signal wires.
  • HV Battery connected with precharge resistor
    • Relay controlled from DCSW pin connect to ground side of relay wires.
  • CPWM to 12v via 470R resistor. Pulled high to when you want to charge
  • CSDN pin to 12v via 470R resistor. Pulled high to when you want to charge
    • CSDN pin also tied to DCSW signal pin, which pulls it down when precharge is complete.
Process
  1. Fwd and reverse signals high, relays open
  2. CPWM and CSDN pulled high via 470R .
  3. Connect AC input voltage with precharge
    1. DCSW will then close relays and pull down CSDN pin to activate charging.
  4. Activate buck on charger. (By manual web interface or does just having FWD and Reverse high activate this?
  5. To stop, can change chargecur to 0 or switch off inverter power.
